Truck was broken into, quarter glass window needs replaced - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 12-30-2009, 07:10 PM
BlackNGoldRules BlackNGoldRules is offline
BlackNGoldRules is starting off with a positive reputation.
I need some advice guys. Someone recently broke into my ranger destroying the quarter glass window on the passenger side rear door of my supercab. Well, I've been quoting some prices to have it replaced and the average price has been around $400 or more. I can't believe it's that expensive for that tiny little window! My deductible is $250. I was thinking the price wasn't even going to reach the deductible but I was dead wrong on that. Anyway, is there a way I can get a used window and have that put on instead? I want to find the cheapest sollution possible for this. Thanks for any advice.
Old 12-30-2009, 07:20 PM
Rockledge's Avatar
Rockledge Rockledge is offline
Rockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to behold
If you can find one at a wrecking yard you can even do the repair yourself.
To remove the quarter glass window: remove the interior trim to gain access to the window fasteners and unscrew them, then cut the sealant around the window with a razor knife, and it should right pop out.
Old 12-30-2009, 10:39 PM
Are there any tutorials or some kind of instructions on how to remove and replace the window? Maybe I will try and do it myself if it's not a complicated thing to do. Better then spending $250.
Old 12-31-2009, 01:08 AM
Rockledge's Avatar
Check out: Removing Ranger Quarter Glass Window
Your gonna need a T-50 "torx" socket for the seat belt.
Old 01-01-2010, 02:30 AM
Could you tell me what the best way is to remove the cover that goes over the bolt on the seat belt? I don't want to break it trying to get it off. Thanks.
Old 01-01-2010, 11:40 AM
Rockledge's Avatar
Are you talking about the belt guide cover? At the widest part of the cover pull the sides out a little and then push up. The cover should pop off the bolt head, and swing open (there is a hinge at the end).
Old 01-02-2010, 08:37 AM
Thanks for all the info. Another question to bug you with, does it matter what temperature I do this in? I'm asking that because of the new sealant I'll have to apply. If I do this on my own it's going to have to be outside in the cold. Right now, temps are going to be below freezing here for at least the next several days. Thanks.
Old 01-02-2010, 09:47 AM
Rockledge's Avatar
Did you pick up the sealant yet? Most products like that have on the label a temperature range for proper installation.
Old 01-02-2010, 11:02 AM
michigan66's Avatar
michigan66 michigan66 is offline
michigan66 is gaining momentum as a positive member of FTE.
Is just the glass broken or is the framing of the window also damaged? If it is just the glass, can you undo the fasteners that go through the glass and get replacement glass at a salvage yard. If that is the case, the replacement job will be much simpler and can be done in any temperature.
Old 01-03-2010, 12:03 AM
Quote:
I actually haven't even started yet but from what I can see it's just the glass of the window that is broken. So, I can just take the window pane out and put the used one in without having to cut the old sealant out and reapply the new stuff? The diagrams and instructions help a lot but I guess I'll have to get started on this and see everything for myself since I've never done this before.
Old 01-04-2010, 04:23 AM
Another question, once I get the bottom part of the seat belt off, is it just a matter of prying the panel off with a crowbar or long screwdriver? Is there a certain way to do this so I don't crack or break anything on the panel? Thanks.
Old 01-05-2010, 03:19 AM
OK, I got the door panel off finally. Looking at the window, where are the fasteners that you are talking about and how can I get to them to just remove the glass itself? All I can see is the 4 screws coming through with the nuts that screw off of them. I guess that would remove the whole thing. How can I get to the fasteners so I can leave the frame part of it on? Is it possible with that kind of window?
Old 01-11-2010, 03:19 AM
Sorry to start an old thread back up, but I found a used quarter glass window and managed to get the old one off of my truck. I bought 3M Windo-Weld Super Fast Urethane to apply to the window that I'm about to put on. Is this good enough to use? In that link that shows how to install and uninstall the window, it says to use a urethane sealant. Is what I described considered a urethane sealant? It just says super fast urethane so I just want to make sure I'm using the right stuff for this. Thanks.
Old 01-11-2010, 06:20 AM
Fordsflylow's Avatar
Fordsflylow Fordsflylow is offline
Fordsflylow has a great reputation on FTE.Fordsflylow has a great reputation on FTE.Fordsflylow has a great reputation on FTE.Fordsflylow has a great reputation on FTE.Fordsflylow has a great reputation on FTE.Fordsflylow has a great reputation on FTE.
Reads like you have the right stuff.
Old 01-12-2010, 10:54 PM
reddog99 reddog99 is offline
reddog99 is starting off with a positive reputation.
The pdf spec sheet for the Super Fast Urethane says, "Please note that bonding is not recommended below 40F.".
'93 Quarter Glass Replacement stangfan78 1987 - 1996 F150 & Larger F-Series Trucks 5 08-10-2016 03:07 AM
Rear window replacement? wicat3 1987 - 1996 F150 & Larger F-Series Trucks 4 07-25-2013 07:49 PM
Vent window repair jimhackney 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 08-26-2012 04:51 AM
exploding rear window chefjb98 Explorer, Sport Trac, Mountaineer & Aviator 5 06-26-2011 01:12 AM
Quarter window adhesive seperation JD-Iowa Excursion - King of SUVs 3 07-21-2010 09:58 PM
Tags
cost, expensive, f150, fix, ford, glass, pics, quarter, ranger, remove, smashed, swing, taurus, truck, window
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
