Rear Window Washer - Ford Truck Enthusiasts Forums
Rear Window Washer
Old 12-30-2009, 03:13 PM
Big Sky's Avatar
Big Sky Big Sky is offline
Big Sky has a good reputation on FTE.Big Sky has a good reputation on FTE.
Rear Window Washer
On our Excursion, the rear wiper washer is not getting any fluid. It sounds like the motor is pumping, and the reservoir is full of the cold temp washer fluid. Is there a seperate motor for the rear washer? If so where is it located?
Old 12-30-2009, 04:34 PM
tgreening's Avatar
tgreening tgreening is offline
tgreening has a good reputation on FTE.tgreening has a good reputation on FTE.
Under the carpet in the passenger side footwell is where the hose to the rear washer runs. It]s way up in the corner. It comes through the firewall and makes a 90 deg turn. Where it turns there is a 90 deg hose fitting. Check this fitting to see if it has come disconnected. Before pulling up the carpet you might want to check to see if it is wet. If the hose is disconnected in this spot it should be.
Old 12-30-2009, 07:36 PM
amkkba's Avatar
amkkba amkkba is offline
amkkba is starting off with a positive reputation.
I have the same problem. Thanks for the advise.
Old 12-30-2009, 07:51 PM
PatsPOS PatsPOS is offline
PatsPOS is starting off with a positive reputation.
If the firewall hose connection checks out OK, then move to the very rear of the headliner, right where it meets up with the liftgate. There's another connection above the headliner...not HARD to get to, just a pain to remove plastic trim.
HTH,
Pat
Old 12-30-2009, 08:28 PM
tgreening's Avatar
And no matter what, post the result!
Old 12-30-2009, 11:45 PM
Excursion4X4's Avatar
Excursion4X4 Excursion4X4 is offline
Excursion4X4 has a good reputation on FTE.Excursion4X4 has a good reputation on FTE.
I have found with mine if I don't use the washer prior to "cold" weather the old washer fluid seems to freeze in the line. Once a semi warm day comes along and the fluid starts to flow the problem goes awayfor the rest of the season. And I use the -20 stuff year around.
Old 12-31-2009, 10:23 AM
katiesdad7 katiesdad7 is offline
katiesdad7 is gaining momentum as a positive member of FTE.
Quote:
We don't have that problem here in Florida. :-)
Old 12-31-2009, 12:28 PM
howler4x4's Avatar
howler4x4 howler4x4 is offline
howler4x4 is gaining momentum as a positive member of FTE.howler4x4 is gaining momentum as a positive member of FTE.
End of Year Special on washer leaks?
Mine wasn't pushing any fluid onto the glass, so keep the washer on until I heard it flow. Nice lil puddle on the read deck carpet
Had to get to work, so I'll check it out later.
Happy New Year
Old 12-31-2009, 06:03 PM
Scoob5555's Avatar
Scoob5555 Scoob5555 is offline
Scoob5555 is starting off with a positive reputation.
Happy New Year
Exactly what happened to mine this weekend. I forgot until I read this. I need to look at that tomorrow.
Old 01-01-2010, 09:58 AM
lambodesigns lambodesigns is offline
lambodesigns is starting off with a positive reputation.
Must be.... at least mine has the puddle of water on the outside. It's right at the firewall so probably just a disconnected hose but given the weather outside it's going to have to wait a bit. Happy New Year all!
Old 01-02-2010, 07:02 PM
Big Sky's Avatar
Hi Guys-It finally warmed up enough so it turned out I had blue washer fluid on the side of the passenger floor, so I pulled the kicker panel and sill strip, pulled the carpet back and reconnected the hose at the firewall. How it came unhooked is beyond me, it looks like it is a deep connection...
Anyways, my wife and I were talking about how this website has really been a God send. I have received so much help and advice on how to repair our Excursion and Super Duty over the years that it has saved us piles of $$$$ on repairing it myself. Thanks guys/gals for all your help. Happy New Year!
Old 01-02-2010, 07:27 PM
tgreening's Avatar
Excellent, and thanks for sharing the final outcome.
Old 03-17-2010, 07:52 PM
TX Silver TX Silver is offline
TX Silver is starting off with a positive reputation.
I'm a little late to the party, but just wanted to say thank you.
I checked the passenger carpet after reading this and found that it was just a tad wet (understatement). It turned out to be the connector at the firewall. What an easy fix once you know where to look.
Thanks again.
TX
Washer Fluid Leak Ex03AK Excursion - King of SUVs 16 01-07-2017 04:59 PM
Wiper action via Wash Button Just Strokin 6.7L Power Stroke Diesel 4 12-01-2016 07:01 AM
Universal Windshield Washer Kit Chea77F150 1973 - 1979 F-100 & Larger F-Series Trucks 14 12-21-2011 04:26 PM
Rear window washer Escape055 Escape & Escape Hybrid 4 11-14-2009 09:35 AM
Front Windshield Wiper Washer Problem k7ikuzus1k Excursion - King of SUVs 4 06-25-2008 01:31 PM
Tags
05, 2002, excursion, fluid, ford, hose, line, location, odyssey, problems, rear, resevoir, washer, window, windshield, wiper, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
