Dark Chamois Metallic 8A?
Hmmm, Rattle cans are not the same base as factory paint. Just went through this, the factory is a basecoat-then a clear coat, rattle can is an all-in-one, and they don't like each other, (one will lift off the other in time).
This is why with a small repair, it is sanded down to bare metal the area is repaired and, here's the key, the repair color coat is "feathered" into the existing color, just in the repair area, BUT the whole panel must be clear coated.
A 3" dent on a 8 foot bed = a 5" paint repair, but the whole bedside is re-cleared.
That is,.....if you want it to match and stay on. IF you are running a "woods bomber" or a "partking lot jockey" Rattle away!
Another member had found the Wimbleton White in a Plastikote rattler. I was hoping there was another reasonable match for the brown that may have been found.
It definitely ain't a beauty thing - just a "make it close" thing.
on
Wimbledon White is a standard color ... Dark Chamois Metallic 8A is not!
How about Ford Dark Chamois Metallic.
-Enjoy
fh : )_~
-Enjoy
fh : )_~
Why not buy the paint you need with thinner, mix as needed and use this to spray it,
Preval 2 Pack (SKU# 0225)
Dave ----
Dave ----
