Fuel pressure Regulator location
Old 12-30-2009, 01:45 PM
austinray's Avatar
austinray
austinray is offline
I have a 2002 F150 4.6 with the same starting problem that I have read about in previous post's about hard to start after shutting engine off and setting for approx. 30 minutes then trying to start again. I have narrowed it down to the fuel pressure regulator. I can cycle the ignition 4 or 5 times and it does start right up. However, from reading the posts I understand the FPR should be located on the fuel rail and be a easy replacement. Also looking at pictures online of the replacement FPR and the only thing that looks like the one it calls for is made onto the fuel rail on my truck. My question is has anyone ran into one that is made onto the fuel rail? It is possible that I am looking at the wrong part on the truck but this is the only one that looks just like the pictures but is not a quick change part. This one would require replacing the entire fuel rail assembly.
Thanks,
Old 12-31-2009, 12:41 PM
austinray's Avatar
austinray
Update
Well I was wrong. After prying on it some more it does come apart as everyone has said. However it was not easy to come apart. The o-ring was holding it together better than one would expect. It two of us about an hour to get it to separate using different tools to pry with but it finally did separate from the fuel rail.
Old 12-04-2010, 08:47 AM
Billsinca's Avatar
Billsinca
Billsinca is offline
i think i need to change mine also.
was there alot of pressure behind it?
did it solve your problem?
how does the new one stay in place?
thanx
Old 12-05-2010, 12:12 AM
Dr. Rik's Avatar
Dr. Rik
Dr. Rik is offline
What are you going afer the fuel pressure regulator for, that having to cycle the key several times screams of the fuel pump. For what its worth I have replaced hundreds of fuel pumps, and If im right I only remember 1 or 2 regulators being replaced. good luck.
Cptn Rich
09-25-2020 07:05 PM
COLD1345
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
11-15-2018 12:31 AM
tsalley55
08-25-2015 08:03 AM
kirkharrod
12-10-2011 06:14 PM
fifthwheel01
09-27-2009 06:56 AM
Quick Reply: Fuel pressure Regulator location
