Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Western Region > Oregon Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Oregon Chapter Join Chapter, Leader: Fabmandelux
  #1 (permalink)
Old 12-30-2009, 12:02 AM
blisstruck's Avatar
blisstruck blisstruck is offline
Garage is empty, add now
blisstruck is starting off with a positive reputation.
Question motor swap done carb issues
I just bought a 65 f100 that smoked real bad out of the driver side of the 352(tail pipe) The truck came with a FE with 73 casting numbers on the heads. I ran some seafome through the first, just smoked more. I decided to swap out the motors to see if the 73 was better. 16 hours of work later NO Smoke! I used the holly carb off of the old motor and the Idle screws don't change anything, the truck will not idle without the choke on a bit. Dose this sound as if something is clogged, broken or miss-adjusted? I also have a motorcraft carb that came with the 73 FE is one better than the other? Any help would be appreciated. Thanks 2V carbs <!-- / message --> <!-- sig --> __________________
__________________
Chris Watts. Just because you can doesn't mean you should!
65 F100
4sp npr 435
390 edelbrock intake and carb. long tube headers
16" innie wheels 215 85 16 tires
  #2 (permalink)
Old 12-30-2009, 01:58 PM
bertha66's Avatar
bertha66 bertha66 is online now
1966 Ford F-100
bertha66 is a name known to allbertha66 is a name known to allbertha66 is a name known to allbertha66 is a name known to allbertha66 is a name known to allbertha66 is a name known to all
Having to run with the choke closed a bit sounds like a vacumn leak. I would switch out the carb just to see how it runs.
__________________
Allen D
1966 F-100 4x4 with 390 GT engine
1990 Areostar 2wd XLT ext
1980 Bronco with 460
1976 F250 4X4 Custom with 429
Oregon Chapter Member: To join the Oregon Chapter, click HERE
  #3 (permalink)
Old 12-31-2009, 01:57 AM
46yblock's Avatar
46yblock 46yblock is offline
46yblock is starting off with a positive reputation.
Just put a new kit in it after good cleanup, and sell me your 2100 . But check for vacuum leak first.
Mike
__________________
Mike Southern Oregon
1946 1/2 ton with Y-block, '62 Mercury Meteor S-33, '55 Ford Country Sedan wagon, '64 Falcon Futura, '90 Ranger 4WD, '54 Ford model 600 tractor
  #4 (permalink)
Old 12-31-2009, 04:20 PM
customcab66's Avatar
customcab66 customcab66 is offline
1966 Ford F-100
customcab66 is starting off with a positive reputation.
my 66 did that to me after the carb sat for about a month turned out that a but had plugged up the carb in the air fuel mixture body behind the freont bowl on my holley to an air hose to it and that was that
__________________
Allen D. Jr
1966 Custom cab truck
1967 Fairlane Ranchero
  #5 (permalink)
Old 01-01-2010, 04:41 PM
blisstruck's Avatar
Thanks for the input. I haven't had time to tinker with it yet but will keep you posted. Ya Mike if you need one I am needing to keep this on a skinny budget. when I get the holley sorted out I'll let you Know.
__________________
65 F100
4sp npr 435
  #6 (permalink)
Old 01-04-2010, 11:55 AM
bertha66's Avatar
1966 Ford F-100
Quote:
I think you ment BUG that had plugged that carb, not but. LOL
Where ya at?
__________________
Allen D
  #7 (permalink)
Old 01-05-2010, 11:11 AM
blisstruck's Avatar
Ya I thought it might be dangerous flipping buts into the carb. I had some time to tinker a bit with the carb and sprayed carb cleaner at the base of the carb the idle did pick up slightly I guess that I need to get new gaskets and re install it. where did you blow air into the carb? did you remove the adjustment screws? not real sure that the pickup wasn't from fumes going into th air cleaner. I may chuck the big block and go with a 6 or a 302 I have a 302 anyone know of a 6 I could trade my 360 for ?
__________________
65 F100
4sp npr 435
  #8 (permalink)
Old 01-05-2010, 09:45 PM
1966 Ford F-100
sorry that was a long day besides not all of can be perfect all the timme right lol
__________________
Allen D. Jr
  #9 (permalink)
Old 01-05-2010, 11:12 PM
46yblock's Avatar
I will just throw this out as an option. A retired mechanic friend rebuilds 2V carbs for $40. You supply the kit. Problem solved. Shipping within state shouldnt be much. If you want you can ship it to me, I will take it and retrieve it from him, reship. He only lives 5 miles away and I'm over there fairly often.
I have had Bill rebuild at least 9 2100 Autolites for me, everyone worked perfect. Finally decided to stay and watch from beginning to end, and now am doing my own 2100s. 2300s are basically the same animal. He is a phenom in my book.
Today I dropped by to see if by chance he had an early Ford vacuum advance left over from his Dyno days.
Yep, and as with everything else he does or has, a lot less expensive than other sources.
Mike
__________________
  #10 (permalink)
Old 01-06-2010, 01:28 AM
blisstruck's Avatar
carb man
I will keep that in mind. where in Oregon is are you I am in Salem but often make trips to Portland.
__________________
65 F100
4sp npr 435
  #11 (permalink)
Old 01-06-2010, 02:06 AM
46yblock's Avatar
Basically Grants Pass. Actually 15 or so miles so. of GP, in Williams. Send email or PM if further interested.
__________________
  #12 (permalink)
Old 01-06-2010, 10:37 AM
blisstruck's Avatar
Oh I don't get that far south very often. I may box it up. but not quite ready to let go of it yet.
__________________
65 F100
4sp npr 435
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
