HOW MUCH WEIGHT CAN MY TRUCK REALLY PULL????
Does anybody know at what tow weight a totally stock 2001 F350 7.3L 4X4 DRW will actually max out at? Basically what would it take to stop it in it's tracks. I think she can!!! I think she can!!!!! She's gonna do it!!!Oh man!!! She can't!!!! ( I guess to get the correct answer someone would have to disable some engine safety features) They've made a sport out of this question, the answer maybe there I guess, any fans out there?
All responese are welcomed!!
The question may not be how much but how far.
Back in the '80's a driver dropped a loaded 45 foot semi trailer blocking the driveway where I worked. We jacked up the front to put a road dolly under it, then hooked up a compressor to release the brakes. I then pulled it out of the way with my pontiac ventura, 305 engine automatic trans. I only pulled it a couple hunderd feet out of the way.
It didn't seem to hurt the car any.
We estimated later it was about 55,000 pounds
You are the man.
Back when I did that I was young and didnt know better.
It wouldn't surprise me that my 2000 250 superduty could move a lot more because of the MUCH lower gears 4wd-lo.
With my kind of luck now, I'd be looking for a whole new driveline. If I could afford it, i'd be fun to try a rail car.
I saw a F150 pull start a tractor trailer one summer, made three laps around the parking lot getting it started and running. Dunno how long it lasted after that though. I owned the Ventura for more than a year after the "big pull" without tranny problems. I'll try to find the pics.
I'm guessing well over 100,000 lbs.
"...Rathakrishnan also holds the previous world record for the heaviest weight pulled with teeth when he dragged a lighter 260.8 ton train over 13 feet, 9.3 inches (4.2 meters) on October 18, 2003."
I'm guessing a Super Duty could do better than 260 tons.
_____________________________UPDATE_______________ _______________
OK, I knew this would happen, everyone would ask what variables are in play and then ask for the correct values. The easiest way to solve this problem is to either assume that all variables are positive in nature or will have the best positive effect on the subject,the truck. But, keep in mind I really don't think anyone will either sit down and do the engineering calculations (not saying you guys are dumb) or go out and actual do a field test. So really the purpose of this question is to just see anyone knows of the answer or maybe has story of someone attempting something along the lines of what I am asking. I was just curious if anyone out there knew, that's all. If anyone has any cool stories about someone pulling gigantic loads with a SuperDUTY, I welcome your posts if its credible. Oh and failure would be defined as, when towed object (weight) comes to a permanent halt. Anymore questions let me know and remember this is just a fun question that I wondered about.
Thanks for taking time to contribute.
FYI I'm only 10 .................. so go easy on me Mr. CATFISH_MAN.
LOL you are a funny guy ....
