anyone have a egt probe go through your turbo?
i am about to install a autometer egt gauge in my truck. im going to intall the probe in the manifold. then i got to thinking of how long its going to last or how good of quality this probe is, and i dont want it breaking off after 100k and going through my turbo. has anyone ever heard of this happening? one more question for those who installed the autometer. once you put the plug in the manifold and insert the probe and tighten down the set screw does it leak exhaust gases a bit. i feel that it might leak gases because the probe is not a tight fit through the plug?
on
I did have my probe unscrew and got loose.. Had to put a hose clamp around it and use some wire to keep it from turning.. I would not worry about the probe going into the turbo..
Hint: When tapping the pipe thread, be sure not to go to deep.. keep trying the probe in the threaded hole until you are deep enough.. too deep and you are screwed.. !
santacruzf250
06-09-2009 09:07 PM
southbound35west
12-23-2008 01:14 PM
