52f1 Heater
The guy who is reproducing these goes by the handle "firstrider" on here. You don't have enough posts under your belt yet to send him a PM, but you can probably get in touch with him by posting to his current thread titled, "Magic air fresh air systems". I think he's been supplying NPD with the boots as well. You might also check with them.
There is a discussion going on currently about the heaters that "firstrider" Denny is chatting on. Here's the link:
https://www.ford-trucks.com/forums/9...r-systems.html
Good discussion!
Good discussion!
heater boots
Just poured another one tonight . Have 10 in stock .Both styles . If you have a '51 w/ a Magic Air heater the kick panel entrance should be a 4" round inlet . The other end where it connects to the heater is the same for both yrs. A rectanguler shape 2 & 1/8 " x 4 & 13 /16 " . See gallery for pics of boots . Thanks ,Denny
The '52 boot is the same at the heater end and is almost sq. at the kick panel .2 & 13/16 " tall by 3 & 7/16 wide . Buy from the maker & save $$ .
