Rebuilt 360 engine
Old 03-12-2000, 10:44 AM
stevem77's Avatar
stevem77
stevem77 is offline
Rebuilt 360 engine
I recently overhauled my 1975 360 engine. I completly went with all new parts including valves and oil pump. I replaced the Intake Manifold with an Edelbrock 390 preformer and installed a edelbrok 1406 electric choke carb. I have about 2000 miles since the overhaul. my problem is the engine uses a quart of oil every tank of gas, (about 250 miles). It has 60 psi oil pressure upon start up, but drops to 25 psi at hiway rpm and down to 10 psi at idle after the engine reaches operating temperature. The engine runs fine (no lifter noise or knocking). It does not smoke. What would you recommend I should do to determine the problem?
Old 03-12-2000, 02:40 PM
jowilker's Avatar
jowilker
jowilker is offline
Rebuilt 360 engine
Steve, have you changed the oil yet? What kind, and what wt. oil are you using? Have you been babying the engine?
John
66 F100s
In the still cool hours of the night, you can hear chevys rusting away.
FORDTRUCKMAN1976's Avatar
FORDTRUCKMAN1976
FORDTRUCKMAN1976 is offline
Rebuilt 360 engine
first thing you have to do is find out where the oil is going. at a qt./250mi, I think if it were burning it it would smoke noticeably. I'd drain some coolant out and see if it's in there. I'd also check the air cleaner housing, and check all vaccum lies. you might also want to crawl under the truck with it running, it's possible that its leaking only when it's running, pay special attention to the area around the oil filter adapter.
Old 03-12-2000, 04:36 PM
StockMan's Avatar
StockMan
StockMan is offline
Rebuilt 360 engine
mcfarmer
Modular V8 (4.6L, 5.4L)
02-22-2014 11:07 PM
romeodz
1997 - 2003 F150
11-04-2011 09:58 PM
Ford F834
02-15-2011 02:45 PM
79FordBlake
08-04-2010 10:56 AM
durk
18
08-30-2005 11:11 AM
Quick Reply: Rebuilt 360 engine
