Rebuilt 360 engine - Ford Truck Enthusiasts Forums
Rebuilt 360 engine
Old 03-12-2000, 10:44 AM
stevem77 stevem77 is offline
stevem77 is starting off with a positive reputation.
Rebuilt 360 engine
I recently overhauled my 1975 360 engine. I completly went with all new parts including valves and oil pump. I replaced the Intake Manifold with an Edelbrock 390 preformer and installed a edelbrok 1406 electric choke carb. I have about 2000 miles since the overhaul. my problem is the engine uses a quart of oil every tank of gas, (about 250 miles). It has 60 psi oil pressure upon start up, but drops to 25 psi at hiway rpm and down to 10 psi at idle after the engine reaches operating temperature. The engine runs fine (no lifter noise or knocking). It does not smoke. What would you recommend I should do to determine the problem?
Old 03-12-2000, 02:40 PM
jowilker's Avatar
jowilker jowilker is offline
jowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to behold
Rebuilt 360 engine
Steve, have you changed the oil yet? What kind, and what wt. oil are you using? Have you been babying the engine?
John
66 F100s
In the still cool hours of the night, you can hear chevys rusting away.
FORDTRUCKMAN1976 FORDTRUCKMAN1976 is offline
FORDTRUCKMAN1976 is starting off with a positive reputation.
Rebuilt 360 engine
first thing you have to do is find out where the oil is going. at a qt./250mi, I think if it were burning it it would smoke noticeably. I'd drain some coolant out and see if it's in there. I'd also check the air cleaner housing, and check all vaccum lies. you might also want to crawl under the truck with it running, it's possible that its leaking only when it's running, pay special attention to the area around the oil filter adapter.
Old 03-12-2000, 04:36 PM
StockMan's Avatar
StockMan StockMan is offline
StockMan is starting off with a positive reputation.
Rebuilt 360 engine
5.4 oil psi problem mcfarmer Modular V8 (4.6L, 5.4L) 8 02-22-2014 11:07 PM
97 F150 4.2 fluctuating oil pressure romeodz 1997 - 2003 F150 1 11-04-2011 09:58 PM
What is "Good" oil PSI for a 6.9??? Ford F834 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 7 02-15-2011 02:45 PM
Bearing Clearance 302 79FordBlake 1973 - 1979 F-100 & Larger F-Series Trucks 4 08-04-2010 10:56 AM
More Oil Pressure ?'s durk FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 18 08-30-2005 11:11 AM
Tags
360, engine, engines, enging, ford, motor, rebuilt, remanufacture
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
