loud noise amplified through airbox? - Ford Truck Enthusiasts Forums
Old 12-28-2009, 08:50 PM
Hayelectric1 Hayelectric1 is offline
Hayelectric1 is starting off with a positive reputation.
help please? driving the truck today and it started making a thumping sound that seems to be coming through the air box? went away a couple of times so i drove it home but noise got louder. got the truck home and shut it down and let it sit for two hours, went back and it started hard and the noise was still there. any thoughts? thank you.
Old 12-28-2009, 08:51 PM
also, truck has 200,000 miles and no mods.
Old 12-28-2009, 09:05 PM
RubberDuck's Avatar
RubberDuck RubberDuck is offline
RubberDuck is a name known to allRubberDuck is a name known to allRubberDuck is a name known to allRubberDuck is a name known to allRubberDuck is a name known to allRubberDuck is a name known to all
The only thing I can think of that would cause a "thumping" noise is if the intake hose has gotten super soft and is colapsing and releasing. Other than that, we are gonna need more info on the noise.
Old 12-28-2009, 09:23 PM
its a loud thump,thump,thump. not sure exactly how to describe. when i open the hood it sounds like someone is inside the airbox banging away. thanks for the help. anything thoughts that would help me describe better?
Old 12-28-2009, 09:41 PM
RubberDuck's Avatar
If you can hear it while standing outside looking at it, then it's not the intake hose colapsing. Unless it has a separated piece inside it. Can you pull the intake hose and start it with open turbo and see if you hear it? Also, is the air filter box closed tightly, if so is the filter snug in there? There should be nothing that makes this sound you are describing. Only other thing that comes to mind is maybe a burnt intake valve that's pushing air back through the intake stroke causing the turbo compressor to surge. I'm at a loss here.
Old 12-28-2009, 09:43 PM
ncinirator's Avatar
ncinirator ncinirator is offline
ncinirator is starting off with a positive reputation.
Open the air box and start the truck, take a look. Or don't start it, just open the air box on look around to see whats broke or has marks that should not have marks.
Check the hose, give it a squeeze, see if it collapses real easy or not. Tell us what you see, or post a picture if you aren't sure.
And someone that knows about electrical stuff look at the volt meter delay thread, I posted a video...But don't respond here cause then this gets
Old 12-28-2009, 09:53 PM
thanks, will check those things in the am and get back.
Old 12-28-2009, 10:38 PM
c00nhunterjoe's Avatar
c00nhunterjoe c00nhunterjoe is offline
c00nhunterjoe has a very good reputation on FTE.c00nhunterjoe has a very good reputation on FTE.c00nhunterjoe has a very good reputation on FTE.
could be a bent pushrod causing it
Old 12-29-2009, 06:09 AM
WALJON WALJON is offline
WALJON is gaining momentum as a positive member of FTE.
Quote:
X2 this would make the noise you are describing .
Have you used Either for a starting aid at all lately?
Old 12-29-2009, 12:50 PM
So I just got back in a whopping 9 degrees out there. found the problem, a broken push rod. unfortunately, in the process of getting there i broke the radiator as well. so now that im there should i replace all of the rods? Is there anything else i should do while im in there? thanks
Old 12-29-2009, 01:18 PM
MADVAN's Avatar
MADVAN MADVAN is offline
MADVAN has a very good reputation on FTE.MADVAN has a very good reputation on FTE.MADVAN has a very good reputation on FTE.
What do you mean by the pushrod broke?
It might be time for valve springs.
Bill
Old 12-29-2009, 01:48 PM
well by broke i mean it was broke in two pieces, I pulled the valve cover this am.
Old 12-29-2009, 04:25 PM
Hussler's Avatar
Hussler Hussler is online now
Hussler is a name known to allHussler is a name known to allHussler is a name known to allHussler is a name known to allHussler is a name known to allHussler is a name known to all
Quote:
How did the broken push rod break .. Either to get it started?
Inquiring minds want to know?
Old 12-29-2009, 07:17 PM
not sure what broke it, have had it for two years now and never put a drop of ether to it?? any other thoughts on what did it? had to order in the rods and radiator, will have them in the afternoon tomorrow. anything else i should look at before i put it back together? thanks
Old 12-29-2009, 10:28 PM
ncinirator's Avatar
Nice call.
Sorry its push rods man, wish it was something simpler. Glad you can handle the problem with out worries, and are learning us about something.
Very Loud Noise lhickey212 1997-2006 Expedition & Navigator 9 10-05-2016 10:14 PM
humming noise mediaman67 Explorer, Sport Trac, Mountaineer & Aviator 7 01-10-2014 10:31 PM
knocking noise from left bank valve cover dothedew192 1999 - 2003 7.3L Power Stroke Diesel 11 01-10-2013 09:16 AM
popping noise and smoke. HELP!!!!! rotralisabe Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 17 11-15-2012 02:24 PM
Needle Bearings Found in Oil dnmunch 6.4L Power Stroke Diesel 19 12-04-2008 11:04 PM
Tags
02, 73, air, airbox, box, coming, diesel, f150, ford, intake, key, noise, parts, powerstroke, thump, truck, turned
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
