Rear disc brake swap
12-30-2009, 09:07 PM
Can the rear disc brakes on a 2007 E-350 be easily fitted to the rear axle of my 97 F-250? Would like to have rear disc and also have an emergency brake too, what all is involved to do this?
12-31-2009, 12:05 AM
no, 99 and up went to a metric bolt pattern so the hub will be wrong for sure. I dont even recall if the 2007's still had a Sterling rear axle under them or not.
Diesel Rod
12-31-2009, 08:24 PM
It might be able to be done but not easily. You would have to cut the flange off your axle tube and weld a newly built one back on in the correct spot to match the brake caliper bracket.
12-31-2009, 10:28 PM
01-01-2010, 07:02 AM
Thanks will pass looks like a project only have enough time for a quick swap......
01-02-2010, 11:08 AM
on
BjornF16
11-18-2016 03:17 PM
mspin54
10-01-2016 12:13 PM
bigdan1979f-250
01-07-2013 01:32 PM
pdrhodes1
03-24-2009 12:20 AM
Dalamatition
07-16-2005 12:58 AM
1997,
95,
96,
97,
axle,
brake,
brakes,
conversion,
disc,
f150,
f250,
f350,
ford,
rear,
sterling,
swap,
trucks
