truck wont run dtc's # p1670 and p0340
I have a 99 250 7.3 and I'm getting dts codes p1670 and p0340 the truck started but run ruff now just turns over and like tries to fire so its like cranking fire cranking fire like it out of fuel almost but got fuel and new filter so any help out there would greatly be appreciative thanks
The P1670 – When a commanded Injector Driver Module (IDM) response is not received this fault is set. Could mean an Under Valve Cover Connector (UVC) having come loose.
If you lie under the radiator and look towards the passenger side of the motor you'll see it. A sensor with two wires going to it. Also that 1670 error can mean that the IDM isn't getting at least 10.1 volts to it. Here is link on Guzzles site with a pic...
http://www.guzzle7pt3.com/cps.php
Candi Dokey
08-15-2016 10:27 AM
jeronlines
18
12-10-2010 10:46 PM
