Shock absorbers for Mustang II front end
I just installed new coil springs in the truck (1954 F100) and the shock is approx 3/4 of an inch too short to re install due to the new springs being so firm
I was using the Monroe 32118. Does anyone know of another model with a slightly longer overall length?
Or possibly a different vehicle that uses a similiar shock
Two part story;
Is this with the A-arm unsuspended (hanging down) or with the vehicles weight on it? In road state the shock would / should seldom be fully extended, it sounds like jacking up on the lower A-arm will not get enough compression of the coil spring to attach the shock, is the engine etc in vehicle?
Any good (?) parts store or somewhere on the net will be a listing of Monroe shocks by part number / dimensions.
OK, but you didn't address if the engine is installed, or if your vehicle weight in on the front. You won't be able to collapse the spring without weight on the nose to install the shocks, so if you have a bare frame up front, don't worry about them until you're closer to finished. That 3/4" will take care of itself then. This is all perfectly normal.
gmammakn
06-25-2012 12:04 PM
Bluzilla
06-07-2012 09:56 AM
crewcabdave
10-04-2011 04:33 PM
caddywhompus
1978 - 1996 Big Bronco
01-12-2004 08:38 PM
