Wheel clearance ?
Received 4,132 Likes
on
Wheel clearance ?
Since I've put the body back on my frame with the lowered suspension package I've got an issue with clearance on the front fenders. I can correct it by going with bigger diameter rims and a deeper offset. The tires are tucked up into the wheel well opening about an inch and a half but are only 1/2'' away from rubbing the fender not allowing me to turn the wheels without hitting the fenders.
What I need to know is how far in from the fenders do I need my tires to be so I can prevent them rubbing. I have the stance that I was looking for and would like to keep it. I know that quite a few of you have lowered trucks and would appreciate your input.
John
The stance on this truck is about the same as my panel
John
Had this dilemma once, put rubber spacers, the flat ring type, under (or above can’t remember) the coil springs and it didn’t raise it much but got just enough clearance so that the tires would clear (but the night time metal sparks over bumps went away, damn.)
Got pictures of car, can't show, other make!
That Truck Looks so good, I'd just drive it in a straight line
There is an aluminum tool designed for wheel clearance that mounts to your hub. It holds a loose tire. It's basically an adjustable wheel simulation. It has graduations on it and you adjust it to get the readings you want for offset - width etc. It's possible some of the more progressive shops in your area have one of these and you can dial it in.
Dawg-a-roo
Dawg-a-roo
on
The truck in the picture belongs to another member on here 56viet, I posted the picture to show the comparison stance of my panel. My question was; how much distance my tire needs to be from the fender in order to turn my wheels without the tires rubbing with the truck lowered in this manner. I'm trying to determine what back spacing I need for the rims I'll have to buy.
Thanks again
Thanks again
on
Thanks again
Thanks again
Michigan Rick
on
Jack the truck up and remove a front wheel. Measure distance from the front hub (where the back of the rim would rest) to the inside lip of your front fender. Call Joeblow wheel company and they'll tell you what tire / wheel backspacing combo you need. That is how I did mine than ordered the fronts from Midfiddy.
Michigan Rick
Michigan Rick
on
Stockton Wheels has a nice schematic so that you can get the right setback. Stockton Wheel - Print, fill out and fax us this order form. I agree that 2" sounds about right. If you go too much space it starts looking like a drag racer. Jag
I would sure like to know details about your panel
How you lowered it, what you find works for front and rear wheel sizes and offsets. I was just measuring mine (53 deluxe Panel) yesterday, wondering what I can fit. I dont think I'll be slamming it, but it would be nice to know what youre working with and what works out for you. Thanks in advance! Im leaning towards 15x8 (4.5 bspace) in back with 255 60(or 70) 15's and 15x7 in front with 235 60 (or70)'s, but want to be sure what backspace I need in front if I was to drop it hard. Im assuming the same backspacing as the rear would work but want to be sure before ordering...
on
In your case I'd stick with the original frame as it is no cheaper doing it the way I did and not as much figuring how it is all going to go together, but I have no regrets with the way I've gone, it keeps the mind active,lol.
Happy New Year.
49willard
34
10-09-2016 05:33 PM
ufvj217
1999 to 2016 Super Duty
11-29-2015 02:40 AM
LeoJr
21
07-30-2014 06:21 PM
