Park Brake Equalizer Spring...need solution
My state inspection failed for the parking brake., I have to replace the left rear cable since it retracts but wont release (broken conduit collar where it goes in the wheel housing).
Looking at my Chilton's manual, I realized the spring is missing that connects to the eye in the end of the adjusting rod/nut on the single front cable at the equalizer. It looks like a long spring goes from the rod back to a plate on the crossmember in front of the gas tank.
I can't find anyone listing this spring. Maybe any old spring would do, but what could I look at as a substitute...maybe another truck, model, year...length of spring?
1976/79 F150 4WD Section 23.2 / Parts lists: 39B, 39C
D2TZ2A651C =
BOWMAN SALES & SERVICE in Bowman ND has ONE = 701-523-3257.
No other Ford dealer, no obsolete parts vendor has any.
D3TZ2A651A =
BECKMAN MOTORS in Garnett KS has ONE = 800-385-5441.
ED BENNETT FORD PARTS in Lebanon PA has ONE = 717-272-8762.
DON SANDERSON FORD in Glendale AZ has FOUR = 623-842-8962.
GREEN SALES CO. in Cincinnati OH has FOUR = 800-543-4959.
No other Ford Dealer or obsolete parts vendor has any.
When typing Ford part numbers into websites, REMOVE any spaces or hyphens.
Otherwise you'll get: No Parts Found.
D3TZ2A651A =
Here ya go, note, in this picture the threaded rod is upside down. It should come from underneath, not on top.
ok, completely different than what I have. On mine, there are no c-clamps. Mine has the two rear lines come up and slide through the u-shaped bracket. Then the front cable comes down and goes through a crossmember, and goes through the center of the u-shaped bracket. No spring, no solid-mounted bar (silver one you have that is connected to the spring). I wonder if mine is just missing stuff, or if there are different layouts.
