352 bore and stroke - Ford Truck Enthusiasts Forums
352 bore and stroke
Old 03-19-2000, 06:52 PM
bigblockhead bigblockhead is offline
bigblockhead is starting off with a positive reputation.
352 bore and stroke
A freind is building a 352 and we need to know whats the bore and stroke? Also,cant he use 390 heads on the 352? How about boring,60 over ok on a 352?
Old 03-19-2000, 10:07 PM
Nathan Nathan is online now
Nathan is starting off with a positive reputation.
352 bore and stroke
352 bore:4.00" stroke:3.50"
390 heads will fit but will yield no gains unless you can find GT or HIPO heads. As for overbore, check with piston manufacturers for what sizes are available. I recommend boring JUST enough to clean up the cylinders. A book called "Ford Performance" by Pat Ganahl is a good referance for basic FE building.
Nathan
Old 03-19-2000, 10:45 PM
rick's Avatar
rick rick is offline
rick is starting off with a positive reputation.
352 bore and stroke
What to do with a '66 352 FE wildwindjerry FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 2 04-24-2015 10:56 AM
stroking out a 352 block fluidp FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 4 12-14-2014 04:34 PM
350 VS 352 Frankinstine Ford vs The Competition 7 09-04-2012 12:41 PM
what schould be compression test on 1962 352 rheal FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 1 04-15-2012 07:03 AM
428 crank in a 352? hjm3inpa FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 11 08-02-2003 09:35 AM
Tags
352, bore, ford, stroke
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
