99 F250 7.3 no power to fuel pump - Ford Truck Enthusiasts Forums
Old 12-27-2009, 05:09 PM
fordblue99 fordblue99 is offline
fordblue99 is starting off with a positive reputation.
I have a 1999 F-250 superduty 4X4 with 7.3. y ruck died on me the other day while driving down the road. I had it towed home. I checked the fuel kill switch it was fine, checked fuel filter in ok shape, checked fuel pump no power getting to it, pulled it and hooked it up word good, changed relay in dash behind radio, still no power to pump any ideas would be appreciated.
Old 12-27-2009, 05:26 PM
PaysonPSD's Avatar
PaysonPSD PaysonPSD is offline
PaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputation
Welcome to .
Here's a thread started today about the same problem. CLICK HERE
For a 1999 Under hood fuse #19 for fuel pump.
If you are not getting the WTS lamp check under dash fuse #30 for PCM and fuel bowl heater.
If the PCM is down it will not be able to turn on the fuel pump.
Any questions just post back.
Old 12-27-2009, 08:14 PM
thanks a lot, my truck has been down for a few weeks. I cant believe all it was was a damn 30 A fuse. Some mechanic I am. and I always tell my customers to check the cheapest and easiest things first. Whats cheaper and easier that a fuse. I guess I was just frustrated.
Old 12-27-2009, 08:23 PM
riverrat41's Avatar
riverrat41 riverrat41 is offline
riverrat41 is a splendid one to beholdriverrat41 is a splendid one to beholdriverrat41 is a splendid one to beholdriverrat41 is a splendid one to beholdriverrat41 is a splendid one to beholdriverrat41 is a splendid one to behold
You were just frustrated because it was yours.Had a similiar situation happen to us yesterday.We just chalked it up to being tired and not thinking
Old 12-27-2009, 08:38 PM
PaysonPSD's Avatar
Quote:
Chit Happens.
The fuse most likely blew due to a shorted fuel bowl heater. Did you unplug it before replacing fuse? If not, do so, or it may blow the fuse again.
Edit: Don't be a stranger. A lot of great people and a lot of great info here.
Old 12-27-2009, 10:46 PM
yes I unplugged it earlier trying to see if that was the problem, I have a small leak just above the heater I have been trying to fix it also. I replaced one o ring then found another leek near the one I replaced. What is that thing called that is behind the filter housing above the heater?
Old 12-27-2009, 10:52 PM
PaysonPSD's Avatar
Hope this pic answers your Question.
99 F350 7.3 Died and is still dead Ken99F350dually7.3 1999 - 2003 7.3L Power Stroke Diesel 44 04-27-2016 01:12 PM
01 f250 7.3 no power to the fuel pump gonecrazy 1999 - 2003 7.3L Power Stroke Diesel 8 09-08-2012 01:26 AM
1999 FORD F250 7.3 DIESEL.... WONT START coastal stone 1999 - 2003 7.3L Power Stroke Diesel 15 04-12-2011 09:49 PM
No power to fuel pump mk28090 1999 - 2003 7.3L Power Stroke Diesel 16 02-08-2011 09:23 PM
No start, fuel problem, no power to pump Powerstroke-7.3 1987 - 1996 F150 & Larger F-Series Trucks 13 12-29-2009 02:45 PM
Tags
30, 73, 99, bowl, f250, ford, fuel, fuse, heater, power, powerstroke, pump, pumps, replacing, update
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
