Go Back   Ford Truck Enthusiasts Forums > Misc. > Electrical Systems/Wiring
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 12-26-2009, 09:07 PM
Spydycarnge Spydycarnge is offline
Garage is empty, add now
Spydycarnge is starting off with a positive reputation.
replacing battery/starter relay cables?
I have a 1982 Ford F250 2wheel drive with carbureted 302. There is a cable that runs from the relay to the wheel well were it is held in place by a metal clamp and the cable sleeve was cut away and touching this metal clamp then continues onto the the engine. Is this necessary to to this? would it be good enough to ground to the engine. I only have one battery while looking up cables at local parts store web sites they mention 2 battery system cable set up that requires theuse of 2 different size wires needed. What is the 2 battery set up? Were my wires rigged to replicate this system even through I see no reason for them to.
  #2 (permalink)
Old 12-27-2009, 08:28 AM
subford's Avatar
subford subford is online now
subford is a splendid one to beholdsubford is a splendid one to beholdsubford is a splendid one to beholdsubford is a splendid one to beholdsubford is a splendid one to beholdsubford is a splendid one to beholdsubford is a splendid one to behold
That is the frame ground before going on to the engine block.
It is used for the trailer ground for its breaks and lights.
Also if you do not have a rear bumper it grounds the rear plate lamp.
It may also ground the tank selector solenoid on the frame.
If you have one fuel tank, a back bumper and do not pull a trailer then no you do not need it.
But do not forget that you do need a good 10 GA body ground from the neg post to sheet metal of the body.
__________________
95 F150 302 4R70W EB EX-CAB
94 F53 460 E4OD COACHMEN SANTARA RV
83 F150 Flare Side 351W AOD
77 F250 351M-2V NP 435/4 Speed 4X4
subford@gmail.com
Bill K, Kansas Chapter
  #3 (permalink)
Old 12-27-2009, 01:29 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
1989 Ford F-250
Franklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud of
You can't have too many grounds. If you want to get a new ground cable that does not have that feature, I would run a 10 gauge wire from the frame to the engine block or from the frame to the battery neg terminal.
__________________
Dave F
1989 F250 XLT Diesel
Tags
1982, 2000, 2003, 460, battery, cable, cables, f150, f250, ford, ground, relay, replacing, starter, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
