How to replace brake rotors - Ford Truck Enthusiasts Forums
1978 - 1996 Big Bronco SPONSORED BY:
Old 11-12-2014, 12:42 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Brake Guides
Print Wikipost
Old 12-26-2009, 03:13 PM
Dancoyote Dancoyote is offline
Dancoyote is starting off with a positive reputation.
Question How to replace brake rotors
Hi again,
I tryed to change my brake rotors (with auto hubs), and could not take them out.
I removed brake calipers, but could not take out rotors. Is there something to know about it ?
Thanks in advance,
Daniel
Old 12-27-2009, 01:16 AM
greystreak92's Avatar
greystreak92 greystreak92 is offline
greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.
You need to remove the hubs, then remove the spindle nuts and lock rings. Only after these are out can you get the rotor assembly to come off the steering knuckle. You can then drive the wheel studs out of the hub and rotor assembly and replace the rotor. And as all the really good service manuals say, "Install is the reverse of removal". Just take care not to over or under torque the spindle nut/lock rings lest you end up with terrible wheel wobble (Manifests itself initially as terrible negative camber after installation) or so much pressure on the wheel bearings that you burn them up.
Old 12-27-2009, 01:58 AM
deadeyedevon's Avatar
deadeyedevon deadeyedevon is offline
deadeyedevon has a very good reputation on FTE.deadeyedevon has a very good reputation on FTE.deadeyedevon has a very good reputation on FTE.deadeyedevon has a very good reputation on FTE.
for some years you need the special tool to remove the spindel nut dont ya?
Old 12-27-2009, 02:03 AM
Yes, what Lisle tools calls a Dana axle nut removal tool. It is a large diameter piece of tubing with four small points projecting down into the slots in the spindle nuts. Friend of mine fabricated one years ago before anyone but Spicer/Dana made such a tool.
Old 12-27-2009, 02:07 AM
my 89 ha dthe atuo lockin hubs and needed it..my 96 has SuperW manual and i have no clue whats involeed with removing them
Old 12-27-2009, 02:09 AM
It should be the same. There was a period of time where the spindle nuts were actually hex nuts but I couldn't tell you when or even if they were specific to any particular models.
Old 12-30-2009, 12:01 AM
aurgathor aurgathor is offline
aurgathor is gaining momentum as a positive member of FTE.
You need to remove the auto hubs first, and if you got the 3 screw variety, that's a challenge in itself.
Old 12-30-2009, 09:22 PM
mprice mprice is offline
mprice is starting off with a positive reputation.
The retaining nut on a '96 should be a 2.5" hex. I got mine at AutoZone, 13$ I think. It's a cheap stamped thing but it did the job twice, which is all I needed when I changed over to manuals. It looks more like an old school bell that's lost its handle than a socket.
First remove the outer hub cap that has the three torx screws. Underneath that you'll need to pull out a clip that sits in a groove to remove the hub body. After that there are a few washers and then a locking clip that is a half circle with a leg that sticks into the locknut. I got a set of picks from Advance Auto that help BIG TIME with this job; dental picks would work too.
Old 12-30-2009, 10:33 PM
yea dont forget the half circle clip, there kinda hard to see if theres allot of grease.
Old 05-31-2012, 04:54 PM
beermonger beermonger is offline
beermonger is starting off with a positive reputation.
Anyone know where I can find a diagram of brake rotor removal for an '87 Bronco (Manual hub)?
If a picture is worth a thousand words, then a parts diagram must be worth ten thousand.
Old 05-31-2012, 11:35 PM
NewEnglander's Avatar
NewEnglander NewEnglander is offline
NewEnglander has a very good reputation on FTE.NewEnglander has a very good reputation on FTE.NewEnglander has a very good reputation on FTE.NewEnglander has a very good reputation on FTE.
Oh I've had some good memories changing out my rotors lol.... when you take of the first cap you should be able to see the lock ring, can be a pain to get off if they havent been removed in a while. When you take out the internals I'd put a rag down and lay them in order of removal. Dont forget to re-pack with grease!
Warped Rotors Again!!!!! ARRGGGHHHHH!!!! KJNDIVER 1999 - 2003 7.3L Power Stroke Diesel 27 11-22-2015 08:58 PM
E99 Front brake conversion stemo76 1999 - 2003 7.3L Power Stroke Diesel 6 06-04-2015 10:01 PM
Smoking rear brake - caliper frozen dogerbrown1 1999 to 2016 Super Duty 1 10-24-2011 12:31 AM
Advice for changing brakes and rotors? tcj506 2004 - 2008 F150 40 11-12-2010 09:01 AM
Pulsing brake pedal after brake job mfp4073 Ranger & B-Series 10 11-27-2008 09:37 PM
Tags
1992, 1993, 1996, brake, bronco, change, diesel, f250, ford, remove, replace, roters, rotor, rotors, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
