Replace wheel bearing or whole hub?? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 11-11-2014, 07:39 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Wheels & Tires How-Tos
Print Wikipost
Old 12-26-2009, 01:42 PM
jstanley jstanley is offline
jstanley is starting off with a positive reputation.
Question Replace wheel bearing or whole hub??
Last time I had my truck (2000 F350 V10 4x4) truck in the shop they told me I had bad wheel bearing on the front. Should I have the whole hub replaced or just the wheel bearing? The truck has 126,000 miles and never had any work done on the front end.
While the truck is in the shop should I also have them replace either the other side wheel bearing or entire hub also?
While looking online at hub assy. I have noticed them listed in both course threads as well as fine threads.....Is there anyway to know short of removing one of the bolts??
I have contimplated doing this myself, just not sure? Thanks for the advise.
Old 12-26-2009, 02:02 PM
dkf's Avatar
dkf dkf is offline
dkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to behold
These trucks use unit bearings. When there shot there shot and you replace the entire housed unit. They would last a lot longer if a grease fitting would be put in the right spot on the unit for easy greasing.
Heres a cutaway of what they look like. (Unit with ABS)
How to replace them. http://www.youtube.com/watch?v=c69G2t9u7ak
Old 12-26-2009, 03:00 PM
Thanks for the info. Does anyone have any experience with the hub assy. on ebay? You can get a pair of them shipped for less than one hub from the local Napa??
The video was very informative, but how difficult would it be to remove the brake rotor, they seem to just make that disssapear on the video. Thanks for the help.
Old 12-26-2009, 03:02 PM
Whoops forgot to ask how to tell iof I need the course threaded unit or fine thread?
Old 12-26-2009, 03:18 PM
dkf's Avatar
dkf dkf is offline
Got a link to the Ebay hubs. Honestly for the most part I'm a believer in "You Get What You Pay For" and if I was replacing the unit they would be Timken units.
You remove the caliper and rotor slides off, well sometimes it rusts fast but it comes off. (Several vids on Youtube)
Don't know about what threads you need.
Old 12-26-2009, 03:19 PM
Rugby3's Avatar
Rugby3 Rugby3 is offline
Rugby3 is starting off with a positive reputation.
I would recommend you do this yourself it's not that hard to do and the money you save is well worth the effort! Buy the hubs from a local auto parts store NAPA, O'Reilly Advance whichever you prefer. You will need the "COARSE" threads for yours. There are some that recommend replacing both hubs at the same time and others have done just the side that is bad. I myself did only one side when mine went out.
Old 12-26-2009, 04:40 PM
Old 12-26-2009, 05:01 PM
Rugby3's Avatar
That is a dirt cheap price! I paid $243 for one hub from NAPA. It doesn't look any different other than it appears to be a unit without the ABS sensor, does yours have ABS? I am sure some others who may have bought hubs off E-bay will chime in sooner or later and be able to give you an opinion of the quality of some of their more OEM specific parts.
Old 12-26-2009, 05:32 PM
As far as I can tell mine does not have any ABS wiring in the front, just a brake line.
From my looking around it appears that many dealers may use the same stock photos. They state that they meet OEM standards, but does that really mean a whole lot? I also saw the parts made by United, Powertrain Components, Precision, API, etc.?
Anyone used these brands?
Old 12-26-2009, 05:56 PM
thedaddycat thedaddycat is offline
thedaddycat is gaining momentum as a positive member of FTE.
I think it's hillarious that he's telling you how dangerous it is to use wheel spacers and the whole time that truck's up on just the jack and no jack stand, blocks, not even putting the removed tire under the front end or anything.....
Old 12-26-2009, 06:37 PM
SpringerPop's Avatar
SpringerPop SpringerPop is offline
Too old to be too smart..
SpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputation
I've been thinking of how convenient it would be to have the same rims and tires on a trailer as on the truck. The convenience of sparing and the loading capabilities on the hubs, rims, and tires make it pretty attractive. If I were converting a trailer axle to a Superduty lug pattern, I would consider these hubs, as the price is right.
But not for my truck. Genuine Timkens are all that I'd consider. There are too many little metallurgical and finish details that the Chinese may not take into consideration that would allow them to be true equivalent replacements.
However, now that I grease my bearings once a year, I may never have to replace the hubs again, but only take them off every 60,000 miles to service the needle bearings.
We'll see.....
Pop
Old 12-26-2009, 07:15 PM
bubbasz1's Avatar
bubbasz1 bubbasz1 is offline
bubbasz1 has a very good reputation on FTE.bubbasz1 has a very good reputation on FTE.bubbasz1 has a very good reputation on FTE.
I bought SKS hubs off Ebay, made in USA, no problems, and with the ABS unit you can indeed grease the wheel bearings. For those without ABS I'm not sure.
Old 12-27-2009, 01:46 AM
wallz's Avatar
wallz wallz is offline
wallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud of
I had one of my front abs sensors go, and for the price of one of them from ford I replaced both wheel hubs for less than that. (the new hubs came with sensors) I also purchased off ebay, and have had no problems so far, but have less than 5000 miles on them since replacement. I even kept my original hubs as backup in case, because they are still good, just figured for the price and peace of mind why not just replace all with new.
The course threads were up until the late 02/ early 03. I used the write up in here Welcome to guzzle's 4x4 Needle Bearing Maintenance Web Page for the work. He even has the part #'s for the bolts that you may want to replace. Probably just over few hours work, and that is if you are a rookie.
<input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
Old 12-27-2009, 02:17 AM
Gale Hawkins Gale Hawkins is offline
Gale Hawkins is starting off with a positive reputation.
I am with dkf on quality of parts.
I just when through this with my 2002 Blazer. It has the all or nothing hub unit too. One side was more than expensive than a total front end brake job had it had the replaceable bearings as was the case pre 1997.
Prices were all over the board for the same unit even. O'Reilly was $210 each for the high end National units. Advanced Auto Parts had the same unit for $158. O'Reilly did call and confirm the $158 price and matched it. Advanced had just sold the two they keep in inventory but found the high end version in Timkem brand at Auto Zone at the $158 price so I could it it off of the jack stands.
One had thrown grease and been hot. The other one was making all of the noise it seemed after the fact.
Replace both at the same time unless you are selling it tomorrow.
My bother had the hub assembly fail on a Volvo tractor at 400K miles last week. The road service guy told him Volvo states as PM to replace them at 350K miles. The company could have got both sides done for the price of one had they followed the Volvo PM schedule.
By the way every store had a cheap line too (like on E-Bay) but they had plastic grease seals and actually looked cheap side by side. Not sure about the price for your Ford but do shop. I saved $100 on the two by walking across the street for the very same brand/quality hub.
I did get new rotors and it was a good thing because I could not beat off the old ones with the hubs pulled off. I reused the ceramic pads since they were less than half way down according to a new Wagner set and the wear grove marker on them after 60K miles plus they do not dust the wheels.
It is so nice to be able to talk going down the road without the roar now and the little pat when braking is all gone.
Old 12-27-2009, 06:06 AM
Quote:
I do not need the ABS units, but for a few extra bucks maybe it woudl be worth it if I can grease the bearings......Do they have a grease point?
1992 F-150 wheel bearings Loumos4 1987 - 1996 F150 & Larger F-Series Trucks 2 12-20-2015 07:17 PM
Front wheel bearings blueoval65 2004 - 2008 F150 2 04-05-2015 04:51 PM
front wheel bearings kink1950 1999 to 2016 Super Duty 7 12-03-2014 04:00 PM
front wheel hub assembly tfdcapt 1999 - 2003 7.3L Power Stroke Diesel 32 01-19-2013 02:55 PM
4x4 Front wheel bearings FastBlack Ranger & B-Series 6 08-28-2008 09:54 PM
Tags
1999, 4wd, 99, bearing, bearings, coarse, f150, f250, f550, fine, ford, hub, rear, replace, thread, truck, wheel, wheelbearing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
