Quick head gasket install question
Old 07-20-2019, 09:59 AM
frdf250's Avatar
frdf250
frdf250 is offline
I could have sworn on my FE390 i used copper silicone around the water passages when i installed my heads.
now i am doing a rebuild on my 7.3 and i cant find anything online regarding dry install of the gasket or if i should use silicone around the water passages. I remember when i did an old 6.0 i had it had rubber oring like material around each port- this felpro gasket for my 7.3 does not. if anyone has any advice it would be helpful.
Old 07-20-2019, 02:08 PM
cleatus12r's Avatar
cleatus12r
cleatus12r is online now
Butt-Head
Received 1,972 Likes on 1,107 Posts
All of the head bolt holes are blind (closed ends/don't protrude into water jackets, etc.).
A thin film of oil on the threads and under the bolt heads is all you need.
For what it's worth, I JUST NOW finished slapping the heads on a 7.3l at home.
Old 07-20-2019, 02:54 PM
frdf250's Avatar
frdf250
frdf250 is offline
Ok good, I just put the one side on. For whatever reason I had a cracked oil ring so I need to wait for the other one to come in on Monday. Compared to my 6.0 95ftlbs seems wimpy !!
JWHCMH
06-23-2014 10:30 PM
brads93 idi
12-13-2013 11:11 AM
djmac
05-31-2011 09:06 AM
Josh88Ford
08-11-2008 11:39 AM
pcmenten
01-12-2004 09:33 PM
Quick Reply: Quick head gasket install question
