1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Speedometer out, Check engine light on, Overdrive column switch blinking!!!!
Old 12-26-2009, 12:03 AM
Lacy's Her Name's Avatar
Lacy's Her Name
Lacy's Her Name is offline
2000 SD250 w/5.4l v8
So I just drove from 29 Palms, Ca to Indianapolis (Carmel), IN. A couple days after I get here in the cold, troubles start. My speedometer isn't working, my check engine light is on, and my column gear selector overdrive switch OFF light is blinking. All cab fuses were checked and I briefly looked at the fuses under the hood, to no avail. My truck is driving fine for the few miles I put on it. It's acting ok????? Any ideas????
Old 12-26-2009, 12:20 AM
Fordfanatic4life's Avatar
Fordfanatic4life
Fordfanatic4life is offline
VSS on the rear diff, would be my first choice of a place to start...
try unplugging and cleaning the contacts.. but it is prolly done for and needs replacing...
code reader should help verify thou...
Old 12-26-2009, 12:22 AM
Lacy's Her Name
Will that cause the Overdrive switch to blink and would the check engine light to come on?
Old 12-26-2009, 12:26 AM
redford's Avatar
redford
redford is offline
Received 1,549 Likes on 904 Posts
Yes, it will.
The VSS output is fed to many different systems on your truck, like the speedometer, the engine PCM, the ABS and the transmission controller. Each of these systems use the vehicle speed as part of the process to determine what needs to be done at any given moment.
Old 12-26-2009, 12:32 AM
Lacy's Her Name
How much are VSS and can they be bought at Autozone?
Semper Fi
Old 12-26-2009, 12:43 AM
Lacy's Her Name
Just another question? The VSS is on the side of the transmission and the ABS sensor is on the top of the rear diff? Is all this correct?
Old 11-10-2012, 03:13 PM
TX03EX's Avatar
TX03EX
TX03EX is offline
od light flashing, check engine light on, no speedo, drives and shifts fine.
I have the same issue. Replaced VSS with a factory Motorcraft Unit. Nothing changed. Truck drives fine. Code shows the abs module isnt talking to the PCM? or something like that...ideas?
Southern Buckers
79
01-24-2020 12:31 PM
LuckyGhost
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
01-22-2017 12:05 PM
1995Jeep
1978 - 1996 Big Bronco
09-16-2016 09:20 PM
BigCamper
Electrical Systems/Wiring
02-02-2015 09:54 AM
Quick Reply: Speedometer out, Check engine light on, Overdrive column switch blinking!!!!
