Speedometer out, Check engine light on, Overdrive column switch blinking!!!!
2000 SD250 w/5.4l v8
So I just drove from 29 Palms, Ca to Indianapolis (Carmel), IN. A couple days after I get here in the cold, troubles start. My speedometer isn't working, my check engine light is on, and my column gear selector overdrive switch OFF light is blinking. All cab fuses were checked and I briefly looked at the fuses under the hood, to no avail. My truck is driving fine for the few miles I put on it. It's acting ok????? Any ideas????
Southern Buckers
79
01-24-2020 12:31 PM
LuckyGhost
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
01-22-2017 12:05 PM
My speedometer is not working on 2005 excursion,Engine light on, abs light on and overdrive blinking
Aminmir
07-27-2015 12:04 PM
