Speedometer out, Check engine light on, Overdrive column switch blinking!!!! - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 12-26-2009, 12:03 AM
Lacy's Her Name Lacy's Her Name is offline
Lacy's Her Name is starting off with a positive reputation.
2000 SD250 w/5.4l v8
So I just drove from 29 Palms, Ca to Indianapolis (Carmel), IN. A couple days after I get here in the cold, troubles start. My speedometer isn't working, my check engine light is on, and my column gear selector overdrive switch OFF light is blinking. All cab fuses were checked and I briefly looked at the fuses under the hood, to no avail. My truck is driving fine for the few miles I put on it. It's acting ok????? Any ideas????
Old 12-26-2009, 12:20 AM
Fordfanatic4life Fordfanatic4life is offline
Fordfanatic4life has a very good reputation on FTE.Fordfanatic4life has a very good reputation on FTE.Fordfanatic4life has a very good reputation on FTE.Fordfanatic4life has a very good reputation on FTE.
VSS on the rear diff, would be my first choice of a place to start...
try unplugging and cleaning the contacts.. but it is prolly done for and needs replacing...
code reader should help verify thou...
Old 12-26-2009, 12:22 AM
Will that cause the Overdrive switch to blink and would the check engine light to come on?
Old 12-26-2009, 12:26 AM
redford's Avatar
redford redford is online now
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
Yes, it will.
The VSS output is fed to many different systems on your truck, like the speedometer, the engine PCM, the ABS and the transmission controller. Each of these systems use the vehicle speed as part of the process to determine what needs to be done at any given moment.
Old 12-26-2009, 12:32 AM
How much are VSS and can they be bought at Autozone?
Semper Fi
Old 12-26-2009, 12:43 AM
Just another question? The VSS is on the side of the transmission and the ABS sensor is on the top of the rear diff? Is all this correct?
Old 11-10-2012, 03:13 PM
TX03EX's Avatar
TX03EX TX03EX is offline
TX03EX is starting off with a positive reputation.
od light flashing, check engine light on, no speedo, drives and shifts fine.
I have the same issue. Replaced VSS with a factory Motorcraft Unit. Nothing changed. Truck drives fine. Code shows the abs module isnt talking to the PCM? or something like that...ideas?
Truck not shifting correctly, speedometer not working Southern Buckers 1994.5 - 1997 7.3L Power Stroke Diesel 68 10-02-2016 11:13 AM
My speedometer is not working on 2005 excursion,Engine light on, abs light on and overdrive blinking Aminmir Excursion - King of SUVs 4 07-27-2015 12:04 PM
OD light blinking!!!! 02 F250 7.3 Auto Tranz. CASHER0010 1999 to 2016 Super Duty 13 03-27-2015 03:59 AM
2000 Ford F150 Keeps Blowing Fuses, Service engine soon light is on kg0306 1997 - 2003 F150 12 01-19-2011 09:16 AM
2000 F250 electrical problems gila_dog 1999 to 2016 Super Duty 7 09-08-2007 01:45 PM
Tags
2001, blinking, check, engine, f150, f250, f350, flashing, ford, light, overdrive, selector, superduty, switch, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
