ONLY the EGR Block off plate
Looking only for the EGR Block off plate. My Rig has the delete, but not the Egr block off plate. I've searched only for the block off plate, but only find the block off plates for the cooler. Trying to find the plate so that I can install the headstuds in while I'm playing with the engine. Thanks guys
If your cooler is blocked off...and the exhaust is all going to the hair dryer (tubo) why not plug the EGR valve back in and make the PCM happy? It isn't exactly smart enough to know there no exhaust passing through the EGR valve if the cooler is blocked off. And it wouldn't be causing any harm....as I understand it. Though a tuner will restrict the amount of time the valve is open.
The puter will still throw a cel if it is blocked off but the valve is plugged in code 0401.It is only the early motors that do not throw a cel for low flow for the EGR.The low flow also limits fueling/boost in the upper rpms.The only way to properly delete the egr on these trucks is blocking the exhaust/intake and tuning otherwise it only half of the job.
Right now, I have the egr unplugged and I'm running a SCT X3 for the custom tunes. I'll plug it back in to see what happens. Whoever did the delete only did it half without the plate and I've looked for to block plate to rid that awful check engine light. Will that light ever go out!?!?!?!?!?LOL
Are you sure it is an EGR related code?If his tune has the EGR shut down there should be no way you get any related codes,very strange ig it is a egr code and he has it removed in the programing.
When I got my tune from eric he told me to let him know if I still had and EGR code as some of them were tricky or different? to disable.
And to the OP, your EGR valve being in place HAS ABSOLUTLEY NOTHING to do with your problem.
MI Yeti
Ford Truck Parts for Sale
08-30-2014 01:57 AM
Sean_Memphis
30
03-20-2014 08:45 PM
magwheels
06-20-2007 09:06 PM
