Glow plugs and gpr questions on California emissions truck
I have a 1997 Cali emissions truck. Having a hard time starting this winter in Missouri. If it is under about 40 degrees won't hardly start. It's like it "half" starts or something. A tiny squirt of ether will fire it right up, but I don't like doing that too often. My question is this. I tested my gpr and I had 12.88v into it and 11.3 or 11.7, can't remember for sure out of it. I also noticed in an earlier post that there is a plug in each valve cover you can test gp resistance at. My truck has two plugs not one and each has 5 pins not 8. Does anyone know how to test these plugs and what the resistance should be here. Also is the gpr bad with the lower voltage. By the way, I also get a ton of white smoke for a minute or so on idle after starting, but not if I plug it in . If I plug it in I get virtually no smoke and it starts great.
Thanks in advance,
Mike
Thanks in advance,
Mike
Stick a fork in that GPR, it's DONE. That's more than 1V voltage drop, and the "it's done" limit is 0.3.
The earlier trucks (maybe all OBS?) have four 5-pin UVCH connectors as you've found. Each one connects to two injectors and two GPs. The far outside terminals (#1 and #5, if you're counting) are for the GPs. Test - disconnect the connector, put an ohmmeter on one outside pin on the gasket (other probe of the meter on the battery negative or other good ground). Resistance should be aprx. 1 ohm. Considerably less means the GP is drawing too much current. "Open" (infinite resistance) means the GP is just plain shot.
Thanks for all the info. I will do some checking on the glow plugs and change the relay and let you know. My voltage was with the truck off. When I told a neighbor who is a mechanic about the problems I am having he steered me to think my comperssion is bad and that is what is causing the hard cold starts. How do you check the comperssion on one of these and will a regular comperssion gage work? Thanks for the posts and sorry it took me so long to reply, I have been out of town with the fam for Christmas.
Mike
Mike
It does have a cel, has had for years. I cant remember the exact number, but it is gp monitoring system or something. After reading what some guys have been thru trying to get rid of that cel I haven't messed with it. Last winter it started fine with the cel. I probably do need to use lighter oil though. Because of how easily it starts when plugged in I belive I have a bad relay. I changed a few gp's a few years back (before I new about this site) and put in autolite's so they are probably shot.
Mike
Mike
Josh88Ford
16
12-09-2013 06:38 PM
surfpunk
01-22-2012 07:31 PM
ncline
12-17-2011 09:41 PM
bdrummonds
20
12-20-2008 01:41 PM
