Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty & Heavy Duty
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Super Duty & Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
  #1 (permalink)
Old 12-23-2009, 11:00 PM
garyleif garyleif is offline
Garage is empty, add now
garyleif is starting off with a positive reputation.
Disable irritating "Please observe Speed Limit"
OK, I just bought a new 2009 F350.
I don't know how, but if I go 6 mph over the posted speed limit, I get an irritating "Please observe the speed limit".
anyone know how to disable or blow this up?
Thanks,
Gary
  #2 (permalink)
Old 12-23-2009, 11:59 PM
rollerstud98's Avatar
rollerstud98 rollerstud98 is offline
rollerstud98 has a great reputation on FTE.rollerstud98 has a great reputation on FTE.rollerstud98 has a great reputation on FTE.rollerstud98 has a great reputation on FTE.
Must have GPS in the truck?
  #3 (permalink)
Old 12-24-2009, 08:16 AM
stormsearch stormsearch is offline
stormsearch is starting off with a positive reputation.
Sounds like you have MyKey enabled for that key.
  #4 (permalink)
Old 12-24-2009, 09:47 AM
bnk190 bnk190 is offline
bnk190 is starting off with a positive reputation.
And how does the truck know what the speed limit on each road is?
  #5 (permalink)
Old 12-24-2009, 10:06 AM
speed4tu speed4tu is offline
speed4tu is starting off with a positive reputation.
Quote:
gps tells it.
  #6 (permalink)
Old 12-24-2009, 10:28 AM
msalyer msalyer is offline
2012 Ford F-150
My Garage
msalyer is gaining momentum as a positive member of FTE.msalyer is gaining momentum as a positive member of FTE.
Thanks,
Gary
I don't know about the '09 trucks but in mine I would have to reach across the cab, pull the door lever, and push my wife out. Then slam the door shut. Problem solved.
Sorry couldn't resist.
__________________
2012 Oxford White F150 Screw HD 6.5 4x4 5.0 3:73 LS
2008 Bright Red / Parchment Mustang Convertible 4.0 Auto
  #7 (permalink)
Old 12-24-2009, 11:17 AM
Hybris's Avatar
Hybris Hybris is offline
Hybris is gaining momentum as a positive member of FTE.Hybris is gaining momentum as a positive member of FTE.
Personally I'd go to the dealer and have them reprogram the mykey thing to shut up.
I'm thinking they wouldn't charge you for doing that but that might be wishful thinking.
__________________
1999 F-150 XL 5.4, Auto, 4x4, 8ft bed, ~171750 miles Mods: K&N high flow filter, 2" suspension lift, and Moog Sway Bar Links and Sway Bar Frame Bushings. Aries Brush Guard
KS Chapter - Jared
  #8 (permalink)
Old 12-24-2009, 08:13 PM
tseekins's Avatar
tseekins tseekins is offline
2011 Ford F-150
tseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputation
Reps sent!
Tim
__________________
Tim
SCPO United States Coast Guard Retired
2011 F-150 XLT 4x4 Ecoboost
2010 Ford Focus
2004 Expedition XLT 4x2
FTE Guidelines
  #9 (permalink)
Old 12-26-2009, 05:05 AM
Quote:
Originally Posted by speed4tu View Post
gps tells it.
Wow - I guess I never knew that GPS had programmed into it what the speed limit on each road is. Stupid question but what if the speed limit on the road changes? There is a section where I live where they are fighting to go from 55 to 45.
  #10 (permalink)
Old 12-26-2009, 05:55 AM
senix's Avatar
senix senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
GPS knows it on most all devices, dealer should be able to take care of the mykey thing. You might check your owners manual and see if there is a procedure in it to take care of it your self.
Msalyer-that was priceless!!
__________________
http://www.ford-trucks.com/forums/pi...ctureid=114550
Scott-2008 F250 PSD Crew Cab 4x4, 12K GVWR,
Cooper Discovery STT LT275/70R18's
Banks Ram Air & 6-Gun, Ravelco Alarm System, Frontier Extreme FT. Bumper
2013 40' 4-slider stoneridge 5th wheel coming in at 15,400
http://www.ford-trucks.com/guidelines.html
  #11 (permalink)
Old 12-26-2009, 06:52 AM
juneau76's Avatar
juneau76 juneau76 is offline
2010 Ford F-150
juneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud of
Now that's funny right there; I don't care who you are.
__________________
Brad
2010 F-150 XLT Supercrew 4x4 5.4L
2013 Explorer Limited (The wife's family truckster)
Quote:
You haven't lived life until you've done 110mph in a Yugo
  #12 (permalink)
Old 12-26-2009, 10:10 AM
Firefighter 1406's Avatar
Firefighter 1406 Firefighter 1406 is offline
1999 Ford F-250
Firefighter 1406 has a good reputation on FTE.Firefighter 1406 has a good reputation on FTE.
I agree, the is the funniest post I have seen in a long time. So truthful
__________________
Seth "WE WILL NEVER FORGET" 343 PAA#129
Early 99 F-250 Ext. Cab 4X4 w/7.3 stroker w/ 250,000
DP tuned PCM, 6637 filter, 4" MBRP turbo back, coolant filter, zoodad, Hx, AutoMeter Guages, 1 1/2 inch leveling kit, Warn Premium Hubs, 285 Duratrac's, Firestone Air Bags, Rancho 9000 XL's, Strobes, Western 8.5 MVP, Western Pro Flo Spreader
www.roadsidehelpnetwork.org/
  #13 (permalink)
Old 12-26-2009, 11:09 AM
Greg B Greg B is offline
Greg B has a good reputation on FTE.Greg B has a good reputation on FTE.
Don't have to reach across and open door for ejection here. My hearing is programmed to automatically go deaf when I hear that sound from the passenger side.
  #14 (permalink)
Old 12-26-2009, 12:36 PM
JockD's Avatar
JockD JockD is offline
JockD has a good reputation on FTE.JockD has a good reputation on FTE.
Wait until you get a speeding ticket in the mail based on the gps report to the government. Sounds like the next Onstar "feature." I suspect that Howie will not brag about that one on his Government Motors TV commercials.
__________________
Jock - 2001 F250 Reg. cab 4X4, 7.3L with CCK, auto, 280,000 mi., homebrew pw and pdl, heated towing mirrors with a timer. Stahl Grand Challenger Utility Box, Ride-Rite Air Bags, Big Rear Sway Bar, Walker BTM + Resonator.
  #15 (permalink)
Old 12-26-2009, 01:56 PM
dkf's Avatar
dkf dkf is offline
dkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to behold
Man I'm glad I have a ancient SD, 04'. Don't have any of the crap to deal with and I'm happy I don't.
Can you go into the GPS menu and disable the speed reminders?
Same hear but it works pretty much anywhere, at least until I get hit for not listening.
__________________
"The tree of liberty must be refreshed from time to time with the blood of patriots and tyrants." (Thomas Jefferson)
Tags
2009, disable, f150, ford, gps, igo, limit, limiter, limits, mykey, observe, release, rev, speed, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
