Turbo Oil Leak or CCV Oil? - Ford Truck Enthusiasts Forums
Old 12-23-2009, 11:43 PM
Nick_A_44663 Nick_A_44663 is offline
Nick_A_44663 is starting off with a positive reputation.
Ok, so I have done a ton of reading and have found that oil can accumulate in the valley of the engine from the CCV. I have a 2002 Auto tranny that I have owned for about six months. It is leaking oil, but not much. I would say a spot about the size of my fist after sitting all night. There is no oil in the front of the valley, but plenty at the back of the valley. The intercooler pipes are pretty coated with oil and so my friend who is a diesel generator mechanic pulled the tubes with me and there was a fair amount of oil in them. He suggested that my turbo seals that are internal may be going and that I may have to replace or rebuild the turbo. Could the CCV be putting enough oil into the intake system to cause what looks like an oil leak? By the way great forum. First post because I always had my question answered pretty quickly. Thanks... Nick
Old 12-23-2009, 11:46 PM
mueckster's Avatar
mueckster mueckster is online now
aka Redneck Wrencher
mueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputation
Look closely at the turbo pedestal. Oil leaks a the rear of the valley can come from this area. It may be coming from the EBPV rod opening or the o-rings that seal the pedestal to the turbo or block. Loose boots at the intake spider can leak a fair amount of oil into the valley also.
Old 12-23-2009, 11:53 PM
I will post a pic tomorrow to show the intercooler pipes being coated with oil that makes me think that the oil is coming from them.
Old 12-23-2009, 11:54 PM
mueckster's Avatar
Subscribing.......
Old 12-23-2009, 11:57 PM
flatbeder's Avatar
flatbeder flatbeder is offline
flatbeder has a very good reputation on FTE.flatbeder has a very good reputation on FTE.flatbeder has a very good reputation on FTE.
Welcome Nick...This is a great place to be for all your PSD needs and wants!!!
Old 12-23-2009, 11:58 PM
big poppa's Avatar
big poppa big poppa is offline
big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.
I agree with Roland, could be that EBPV rod on the pedestal(upper left hand corner in pic) and also these o-rings, you have to pull the turbo to get to these , if that the problem
Old 12-24-2009, 12:11 AM
Here are some pics of the intake area that makes me think the leak is coming from this pipe. I will clean with a degreaser tomorrow to narrow the leak down.
<a href="http://www.flickr.com/photos/45916493@N08/4209742977/" title="DSC_1220 by Nick_A_44663, on Flickr"><img src="http://farm3.static.flickr.com/2721/4209742977_30979fd4c4.jpg" width="500" height="333" alt="DSC_1220" /></a>
<a href="http://www.flickr.com/photos/45916493@N08/4210506822/" title="DSC_1219 by Nick_A_44663, on Flickr"><img src="http://farm3.static.flickr.com/2671/4210506822_831bbe8b45.jpg" width="500" height="333" alt="DSC_1219" /></a>
<a href="http://www.flickr.com/photos/45916493@N08/4209742401/" title="DSC_1218 by Nick_A_44663, on Flickr"><img src="http://farm3.static.flickr.com/2602/4209742401_7a85356aea.jpg" width="500" height="333" alt="DSC_1218" /></a>
<a href="http://www.flickr.com/photos/45916493@N08/4210506288/" title="DSC_1217 by Nick_A_44663, on Flickr"><img src="http://farm3.static.flickr.com/2668/4210506288_480451cef9.jpg" width="500" height="333" alt="DSC_1217" /></a>
Old 12-24-2009, 12:32 AM
big poppa's Avatar
Wow, those pics will make our resident FTE brother Miller_feed cry, definetly clean her up, thats a typical oily boots look from the CCV but your oil puddle in the back of the valley sounds like was mentioned earlier, subscribing and welcome to FTE.
Old 12-24-2009, 08:36 AM
Sheldon Plankton's Avatar
Sheldon Plankton Sheldon Plankton is offline
Sheldon Plankton has a good reputation on FTE.Sheldon Plankton has a good reputation on FTE.Sheldon Plankton has a good reputation on FTE.
Quote:
Originally Posted by Nick_A_44663 View Post
......Could the CCV be putting enough oil into the intake system to cause what looks like an oil leak?....
Yes. Definitely. The dirty boots and the oil leak are almost certainly separate issues.
7.3 valley oil leak kshouman 1999 - 2003 7.3L Power Stroke Diesel 10 09-10-2016 11:54 PM
Question about CCV reroute.oil in air intake. calvinbabb 6.0L Power Stroke Diesel 6 11-22-2014 05:34 PM
CCV Mod question dieselsubmariner 1994.5 - 1997 7.3L Power Stroke Diesel 15 11-23-2013 09:06 AM
CCV feed back, turbo pressure filling valley with oil.. dothedew192 1999 - 2003 7.3L Power Stroke Diesel 6 10-03-2010 06:21 PM
plugged ccv pushingxthexedge 1999 - 2003 7.3L Power Stroke Diesel 4 03-13-2008 12:00 AM
Tags
2001, 60, 73, 73l, f250, ford, ic, leak, leaking, oil, pedestal, powerstroke, tube, turbo, valley
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
