I installed a heated mirror switch - Ford Truck Enthusiasts Forums
Old 12-23-2009, 09:26 PM
loubell loubell is offline
loubell is gaining momentum as a positive member of FTE.
After researching a plethora of posts on this and other forums, I found plenty that talked about adding a switch for the heated mirrors, but none that actually showed how to do it. So I says to myself "Self, why don't you do this mod and post up some pics for the nice folks on FTE who have helped you out so much with your 03". So I did it and took some pics. I was doing the fog light mod and the idle up mod at the same time (to complete the trifecta) but I wont go into those as they have been well covered in the past.
For starters, my original plan was to simply tap a switch into the heated mirror wire coming from the back of the fuse block. But when I looked at the back of it, the wires DO NOT all correspond to where the fuses, breakers, and relays are. After researching, I could not figure out which wire it was, so I decided to just do it in the front.
The first task was tapping into the fuse slot #9. Here is the location on my 2003 6.0
(Click on the little pics for bigger pics)
The mini fuse taps that are available are a little too wide to use side by side. So instead, I cut a mini fuse in half, stripped the plastic off, and crimped a butt connecter on each one.
I labeled all of the wiring with a P-touch label maker, so that when I (or a mechanic) tears into it in 10 years, it will not be a big guessing game as to what all of the different wires are for.
Here are the fuse taps and the newly labled wires inserted into the slot for fuse #9. Just peeking out his head on the left is the new 20 amp fuse with holder that I spliced in line.
And the 30 amp switch with a yellow LED while on. All wiring labled.
The finished product, with "Mirror Heat" P-touch label, left side of steering column.
No more heated mirrors in the summer. The heating elements should last twice as long now.
Old 12-23-2009, 09:42 PM
bismic's Avatar
bismic bismic is offline
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
Nice post loubell! Thanks for taking the time to write it up (reps to ya).
Old 12-23-2009, 09:46 PM
dschuffert's Avatar
dschuffert dschuffert is offline
dschuffert is gaining momentum as a positive member of FTE.dschuffert is gaining momentum as a positive member of FTE.
Great information! Thanks for sharing!!
Old 12-23-2009, 10:16 PM
2001400ex 2001400ex is offline
2001400ex is gaining momentum as a positive member of FTE.
I have wondered about the heater mirrors. How do they turn on? Please don't tell me it is something stupid like the first 10 minutes every time you turn on the truck. Mine doesn't have a outside temp gauge, so always kind of puzzled me... LOL
Old 12-23-2009, 10:56 PM
From What I heve read on the web, unless you have a switch (like on some later F250s) they are always on. I verified this with my multimeter.
Old 12-23-2009, 11:01 PM
conger's Avatar
conger conger is offline
conger is gaining momentum as a positive member of FTE.conger is gaining momentum as a positive member of FTE.
Quote:
Great info... I always thought it would be good to turn off in the summer.
Old 12-23-2009, 11:03 PM
bismic's Avatar
The issue I have w/ them is all the "spotting" - it really interferes w/ the view.
Old 12-23-2009, 11:12 PM
Quote:
That answers why all the spots. I was just wondering that the other day, why these mirrors have spots after a half hour driving in the rain.
william_04_x's Avatar
william_04_x william_04_x is offline
william_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputation
On Excursions they're activated with the rear window defroster switch..
(stupid emoticon huh?)
Nice work loubell!!
Old 12-24-2009, 05:43 AM
Nice Work Truck's Avatar
Nice Work Truck Nice Work Truck is offline
Nice Work Truck is a splendid one to beholdNice Work Truck is a splendid one to beholdNice Work Truck is a splendid one to beholdNice Work Truck is a splendid one to beholdNice Work Truck is a splendid one to beholdNice Work Truck is a splendid one to beholdNice Work Truck is a splendid one to beholdNice Work Truck is a splendid one to behold
Great wright up loubell, reps to you.
I did the same thing buy hooked them to a upfitter switch.
I only turn them on when the mirror is fogged or icy.
Old 12-24-2009, 07:38 AM
CombatMedicF-250's Avatar
CombatMedicF-250 CombatMedicF-250 is offline
CombatMedicF-250 is starting off with a positive reputation.
Great work! Great Write-up...well done for sure!
Reps Sent!
Old 12-24-2009, 10:36 PM
flamebuster flamebuster is offline
flamebuster has a good reputation on FTE.flamebuster has a good reputation on FTE.
Great write up Loubell what color wire did you tap into for the mirrors and where did you locate it at.. info is greatly appreciated..
Old 12-24-2009, 11:23 PM
zhilton's Avatar
zhilton zhilton is offline
zhilton is a name known to allzhilton is a name known to allzhilton is a name known to allzhilton is a name known to allzhilton is a name known to allzhilton is a name known to all
Good work!
Old 12-25-2009, 07:39 AM
jdadamsjr's Avatar
jdadamsjr jdadamsjr is offline
jdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputation
Quote:
Wow, Is that true W ? for all model years ?
We here in North Texas had a WHITE Christmas last nite and
while slip sliding up I-35W in the BLOWING snow, I didn't have my rear defroster on and the mirrors were clear.....
Also didn't know that some worked all the time either
What a conundrum
Now you guys got me thinking about it !
Old 12-25-2009, 03:33 PM
From my original post
If anyone knows which wire coming out of the back of the fuse block it actually is, post it up with some pics so that the members on this board will have two ways to wire up a heated mirror switch.
Projector headlight retrofit 86F150302 1987 - 1996 F150 & Larger F-Series Trucks 26 12-30-2016 09:25 PM
Removing door panels to replace mirrors Killer RC 1968-2013 Full Size Vans 24 05-13-2015 06:24 PM
Mudfest pics Duct Tape Racing Offroad & 4x4 2 04-20-2011 03:07 PM
RDP CCV Kit & RDP 6637 Filter Kit Install RIFF RAFF Skip1970 1999 - 2003 7.3L Power Stroke Diesel 7 05-21-2010 08:58 PM
Just some new Additions to the Truck. TheBigBee 1999 to 2016 Super Duty 30 02-08-2010 11:09 PM
Tags
1859, 2008, 99, f250, f350, ford, heated, hooking, kit, mirror, mirrors, power, switch, truck, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
