I installed a heated mirror switch - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 02-17-2010, 09:42 AM
solaratomic's Avatar
solaratomic solaratomic is offline
solaratomic is starting off with a positive reputation.
How many amps do the mirrors draw? I'm gonna hook mine up to an uplifter switch and need to know whether to put it on one of the 30amp or 10amp switches.
  #32
Old 02-17-2010, 10:18 AM
idgara73612's Avatar
idgara73612 idgara73612 is offline
idgara73612 is starting off with a positive reputation.
I've heard numbers up to 4 amps each, so if that's true you should be fine with the 10 amp switch, but that's just from poking around here - couldn't tell you for sure.
Now, for my own question... How do you know which connector is the 270D connector? Would this be in the owner's manual somewhere? Or is is printed on the connector itself? Thanks!
  #33
Old 02-17-2010, 10:40 AM
Probably labeled on a little piece of tape on the connector, usually thats how they're done
  #34
Old 02-17-2010, 10:53 AM
flamebuster flamebuster is offline
flamebuster has a good reputation on FTE.flamebuster has a good reputation on FTE.
The original poster Loubell used a 20 amp fuse, in slot #9, I would say that is the same same size the factory uses.
  #35
Old 02-17-2010, 01:19 PM
Update: 2006 uses a Green wire w/violet stripe also, connector is not labeled but it is almost directly behind the mirror heat fuse. This connector is at the bottom of the fuse block, just about in the middle(looking directly at it). It has a looped light blue wire w/pink stripe (gos in loops and gos back in) and the release is on the end of the connector. This should help you identify it. I decided to go with the Aux 2 switch since the factory fuse is 15amps, now I just have to go get a large 15 amp fuse for the switch fuse in the block so the mirror wiring doesn't burn up for some reason. Based on the wire size I think I could've used Aux 3 but why take the chance if I'm not useing Aux 2 for anything else. I recommend a SMALL jewelers flathead screwdriver to pry out the red lock in the center of the connector and then to push in the back of the connector to get it to release the wire, it's no prob if you use that. Hope this helps.
  #36
Old 02-17-2010, 02:39 PM
Well my heated mirrors are now on Aux 2 and I went ahead and did the Fog light mod while I was in there...had already done the high idle mod, it's on Aux 4. Glad I don't have that 8 amp draw all the time now the alternator on these trucks isn't exactly oversized by any means.
  #37
Old 02-17-2010, 06:17 PM
Ok, went to the parts house. Apparently they don't make a 15 amp fusible link. So after I got home I rewired the mirror to Aux 3 and put the 15 amp mini fuse in the Aux 3 port. Figured it would be alright since they're both 18 gauge wires.
  #38
Old 03-07-2010, 12:15 PM
Finally got my heated mirror switch installed last night.!! Installed a toggle switch on the dash below the gauges along with all my other switches. Since the mirrors are already fused I just installed the swich in line, had to add about 8" to each side to reach the swich and I installed a led. indicator light to let me know when they are on. Took all of 30. minutes. Thanks to all the info and the pictures on here it was a simple task, and yes it was the dark green/purple stripe wire, was thrown off at first by the light green/purple stripe on the same plug..Came back looked at pics. and figured it out.
Thanks guys for all the information......
  #39
Old 03-18-2010, 11:56 PM
1975StroppeBaja's Avatar
1975StroppeBaja 1975StroppeBaja is offline
1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold
Got mine installed last weekend. I had my dash tore apart to install my switches and I was able to reach into the headlight switch hole to do the cutting and splicing.
So all you have to do to avoid dropping the fuse panel is to remove the headlight switch and the front part of the dash
Heated mirror control along with wiper shaker (not installed yet) and backup camera. The small rocker switch is for a truck cap light.
  #40
Old 03-19-2010, 06:01 AM
Nice Work Truck's Avatar
Nice Work Truck Nice Work Truck is offline
Nice Work Truck is a splendid one to beholdNice Work Truck is a splendid one to beholdNice Work Truck is a splendid one to beholdNice Work Truck is a splendid one to beholdNice Work Truck is a splendid one to beholdNice Work Truck is a splendid one to beholdNice Work Truck is a splendid one to beholdNice Work Truck is a splendid one to behold
VERY nice job
  #41
Old 03-19-2010, 11:38 AM
amdriven2liv's Avatar
amdriven2liv amdriven2liv is offline
I'm hitting easy street
amdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputation
Looks very clean, Like those switches. Good job.
  #42
Old 03-19-2010, 06:28 PM
Quote:
+1 Looks like ford put it in there
  #43
Old 03-19-2010, 08:14 PM
Thanks guys!
Appreciate the kind words
  #44
Old 03-20-2010, 02:46 AM
ol-blu's Avatar
ol-blu ol-blu is offline
ol-blu is starting off with a positive reputation.
What are the two other switches for??? I see the heated Mirror one but dont know what u used the others for??
  #45
Old 03-20-2010, 05:29 AM
Says it all right there. Nice labels.
Projector headlight retrofit 86F150302 1987 - 1996 F150 & Larger F-Series Trucks 26 12-30-2016 09:25 PM
Removing door panels to replace mirrors Killer RC 1968-2013 Full Size Vans 24 05-13-2015 06:24 PM
Mudfest pics Duct Tape Racing Offroad & 4x4 2 04-20-2011 03:07 PM
RDP CCV Kit & RDP 6637 Filter Kit Install RIFF RAFF Skip1970 1999 - 2003 7.3L Power Stroke Diesel 7 05-21-2010 08:58 PM
Just some new Additions to the Truck. TheBigBee 1999 to 2016 Super Duty 30 02-08-2010 11:09 PM
Tags
1859, 2008, 99, f250, f350, ford, heated, hooking, kit, mirror, mirrors, power, switch, truck, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
