I installed a heated mirror switch - Page 2 - Ford Truck Enthusiasts Forums
Old 12-25-2009, 04:53 PM
D8chumley's Avatar
D8chumley D8chumley is offline
Resident smarta$$
D8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud of
Nice writeup, Lou. Rep sent!
Old 12-25-2009, 06:03 PM
flamebuster flamebuster is offline
flamebuster has a good reputation on FTE.flamebuster has a good reputation on FTE.
Sorry Loubell, after I inlarged photo I figured out your procedure, ( left my glasses in the truck), Very clever and simple never would have thought of it... I think I will be doing the exact same thing.. Thanks again and Merry Christmas..
Old 12-25-2009, 06:49 PM
zhilton's Avatar
zhilton zhilton is offline
zhilton is a name known to allzhilton is a name known to allzhilton is a name known to allzhilton is a name known to allzhilton is a name known to allzhilton is a name known to all
Quote:
Originally Posted by loubell View Post
If anyone knows which wire coming out of the back of the fuse block it actually is, post it up with some pics so that the members on this board will have two ways to wire up a heated mirror switch.
This is from the tech folder...but it might help:
http://www.ford-trucks.com/forums/12...-all-done.html
The OP in that thread claims on the '03 at the door panel it's a black wire with a white tracer. I haven't dug into the wire of my '04 (heated mirrors w/ the turn signals is on my "to do list") yet so I don't know that for a fact.
Old 12-25-2009, 07:26 PM
Joks79 Joks79 is offline
Joks79 is starting off with a positive reputation.
I will be doing this after I get the uplifter switches in my truck. Also going to put the plow lights on it.
Old 12-25-2009, 08:42 PM
1975StroppeBaja's Avatar
1975StroppeBaja 1975StroppeBaja is offline
1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold
Nice job, reps to you!
This is of the three switches on my to-do list. A switch for this, a switch for 2WD-LO, and a switch to activate my backup camera display if I'm not in reverse.
Thanks!
Last edited by 1975StroppeBaja; 01-22-2010 at 10:34 PM. Reason: fix spelling error
Old 12-26-2009, 09:51 PM
loubell loubell is offline
loubell is gaining momentum as a positive member of FTE.
Yea, I saw that too, but that is the wire at the door, and I assume there must be one for the left door and the right door, which seemed way to complicated for me to try and tap into.
Old 01-13-2010, 11:59 AM
Culvert Culvert is offline
Culvert is starting off with a positive reputation.
subscribing, another mod on the list to do!
Old 01-22-2010, 10:00 PM
amdriven2liv's Avatar
amdriven2liv amdriven2liv is offline
I'm hitting easy street
amdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputation
This is for 2004 F350
This is for 2004, F350
Called Ford dealer in Ashland, Oregon where this truck was originally purchased. Jason was very helpful.
They told me this: DarkGreen/Violet is wire color
Connector on back of fuse block:
270 D pin #8
And under Passenger kick panel:
C210 pin#4
Disclaimer: Some people say I don't listen very well. Or, it goes in one ear and out the other.
I will be doing this mod tomorrow. If you see something strange in the pictures I'm placing of what I took pictures of location of wire, let me know. Pictures are now in my Albums.
I will do a test before starting. I'm going to pull the Dark Green/ Violet wire first thing in the morning to check the temp of the mirrors to make sure I disconnected the right wire.
____________________________________
2004 F350 6.0L 4x4 CC LB KR
Coolant filter
High idle
fog light fix
Always bright overhead
cat delete
Old 01-22-2010, 10:58 PM
I'm looking forward to your install, testing, and results. I think it's great for the members of this board to have 2 different ways to do this mod.
Old 01-23-2010, 01:45 AM
Headviking's Avatar
Headviking Headviking is offline
Headviking is gaining momentum as a positive member of FTE.Headviking is gaining momentum as a positive member of FTE.
2007 SD. Heated mirror does automatically come on when started.
Old 01-23-2010, 10:26 AM
Quote:
Yes but do they ever go off automatically? That's what the switch is for. All of ours come on automatically but they stay on all the time.
Old 01-23-2010, 06:43 PM
270 D pin #8
C210 pin#4
Well, it is the Dark Green/Violet wire. I started this by making sure both mirrors were actually heating. First temp was 44f, let them heat for about 5 min. then they were right at 70f.
Turned everything off, and tore into the fuse block. ( oh, I taped a bag of ice to the passenger mirror to cool down, driver side was in the sun ) Located the wire at connector 270D and reomoved it from the connector, which is a pita. Turned the koer to make sure the mirrors wouldn't heat back up. After 5 min. They were still cold.
Then, just went about wiring the darkgreen/violet wire into a switch on the dash. After installation, tested the switch to the mirrors and let sit. Quite a while, lost track of time. When I did test the temp. on the mirrors, both were right at 80f. Nice and toasty!
While I was screwing around, went ahead and installed LEDs for heated seats. Right where Benchwrench placed His. I did find some orange ones though. They also had Red and Green. These were found in the second drawer at Radio Shack part#276-0272. (these were a tad bigger, took a 9/32 pilot hole)
http://www.ford-trucks.com/forums/79...ndicators.html
Thanks loubell for the original mod post. This was fun.
And as said before, the wire color and location was for a 2004, not sure what newer or older would be. There are pictures in my albums where the 270D connector is located.
Time for an Adult Beverage! (or 2 )
  #28
Old 01-23-2010, 10:21 PM
villestrip villestrip is offline
villestrip is starting off with a positive reputation.
Does anyone know if the wire color is the same on a 06?
  #29
Old 01-23-2010, 10:37 PM
Quote:
I ended up calling the dealer for the color on my 04. Might try them.
  #30
Old 02-16-2010, 08:42 PM
idgara73612's Avatar
idgara73612 idgara73612 is offline
idgara73612 is starting off with a positive reputation.
Villestrip, did you end up figuring out the wire color for an '06? That's what I have.
Projector headlight retrofit 86F150302 1987 - 1996 F150 & Larger F-Series Trucks 26 12-30-2016 08:25 PM
Removing door panels to replace mirrors Killer RC 1968-2013 Full Size Vans 24 05-13-2015 05:24 PM
Mirror connector schematic 1MrBrian1 1999 to 2016 Super Duty 6 10-29-2014 09:03 PM
Mudfest pics Duct Tape Racing Offroad & 4x4 2 04-20-2011 02:07 PM
Just some new Additions to the Truck. TheBigBee 1999 to 2016 Super Duty 30 02-08-2010 10:09 PM
Tags
1859, 2008, 99, f250, f350, ford, heated, hooking, kit, mirror, mirrors, power, switch, truck, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
