General Automotive Discussion
One tire blows out and tire shop wants to change all four!!!
Old 12-25-2009, 05:47 PM
Ford_Six's Avatar
Ford_Six
Ford_Six is offline
There is no room to work on anything that you need to get to in that engine bay.
My wife's XJ wound up with a cracked block, which I thought was an external hg leak. Pulled the head, and that's where the fun started. No locating dowels, and you have to remove/replace the right rear head bolt with the head, there isn't enough room to get that bolt in and out with the head in. So, you have to make a couple short bolts with a screwdriver slot in the top to use as guides, that you can't make too tall or you can't get the head on over them, so you have to fish them out with a magnet and you have to wrap a zip-tie around that rear bolt to install it along with the head.
Oh, then you have very carefully fish this heavy long head in under the cowl, over the studs, be very careful not to touch that head gasket until you're in place, and hopefully one of the half million wires and vacuum tubes doesn't get between the head and block. Manifold bolts are virtually impossible to get to, and in general the whole job was a royal pain. The PCV system is a random jumbled mess of hoses that seem to have been made of a material that was not compatible with crankcase vapors.
Also, AMC should never have been in charge of wiring anything, ever.
Old 12-25-2009, 06:51 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,595 Likes on 1,300 Posts
Originally Posted by tseekins
[/b]
I just recently put tires on my Expy and the tire manager and I were talking away. According his corporate people, the reasoning behind placing the new tires on the rear of a front driver is the rear of the car has very little drive control. The newer tires are supposed to help prevent the back end from fishtailing and coming around.
I'm not so sure I agree with them 100%.
I was considering an AWD Edge as my replacement for the Expy in the future, not anymore.
Tim
If you must run two new and two used, the new ones go on the back, regardless of fwd or rwd. Think about it--you want the front end to let go first, or the back? ALWAYS go for understeer on the street. The back end goes first, and you are ditch/guardrail/mortuary bound....
As for AWD, I think the tire fellers went a little overboard with the OP's situation, as with under 10K miles, unless they were the soft 20k summer performance jobs, there should not have been enough wear to make a difference....
Merry Christmas to all.
Old 12-26-2009, 05:21 PM
rebocardo's Avatar
rebocardo
rebocardo is offline
> I ever want to buy a newer model AWD vehicle of any kind...
I think one of the best and most tolerant AWD systems was found on the Aerostar. Excellent in snow, predicable handling for the most part in all weather, and coupled with the rear L/S and how balanced the ext. length vehicle was, it was excellent. imho. Only problem was if you broke a front axle, but, that was easy enough to overcome.
GM and later Ford too, made wiring harnesses for AMC/JEEP. So, they probably we not in charge
Old 12-27-2009, 12:56 PM
starmilt's Avatar
starmilt
starmilt is offline
All 4x's need matching tire diameter all the way around period, to prevent driveline strain and premature wear and tear on drivetrain components.
I can't belive that with only 10,000 miles you needed even 2 tires unless they didn't have the same brand as different brands will have different diameters, Your spare will always be a different diameter but is safe to drive in to get it a tire repaired.
Old 12-27-2009, 03:06 PM
jroehl's Avatar
jroehl
jroehl is offline
Respectfully, I disagree. I have a '96 Dodge Grand Caravan. It's FWD, and I just put two new tires on it this year due to one wearing poorly. They went on the front. ABS will keep the rear from coming around during braking, and the better traction on the front where most of the weight and the braking power are will get me stopped. Just last night I drove 75 miles through snowy, slippery crap (it took double the normal 1.5 hours), with nary a problem. I've also had some hydroplane moments in it, and came through just fine. In a FWD vehicle, if the back end does break loose, a little countersteer and acceleration will bring it back in line. I prefer oversteer to understeer any day of the week.
Jason
Old 12-27-2009, 05:16 PM
85e150's Avatar
85e150
You prefer oversteer as long as you can induce and control it, like many drivers, myself included. Even with ABS, you can have the back come around without warning if you have poor rubber out back.
If you want to run the new ones up front, fine, but just make sure the ones out back are good, not marginal.
Old 12-28-2009, 05:52 AM
rebocardo's Avatar
rebocardo
I agree, especially anyone that has driven a Chevy truck or car with ABS or worse 4 wheel ABS.
Old 01-01-2010, 06:01 PM
FoxNotch's Avatar
FoxNotch
FoxNotch is offline
Absolutely. Understeer is bad news as far as I'm concerned.
Old 01-01-2010, 09:54 PM
85e150's Avatar
85e150
That must be why EVERY manufacturer dials understeer into their vehicles.
Understeer: The front wheels slide first
Oversteer: The back wheels slide first
Or as they say in NASCAR:
Understeer: The front of the car hits the wall first.
Oversteer: The back of the car hits the wall first.
With understeer, you get off the gas, hit the brakes, and if you are lucky, you scrub off enough speed to regain traction and you go on your way.
With oversteer, you are backwards off the road, into the wall etc. Now jroehl says:
".... In a FWD vehicle, if the back end does break loose, a little countersteer and acceleration will bring it back in line. ..."
That is true, IF you have the room to do it. Usually that countersteering will make you run at least as wide or wider in the corner than understeer, plus the acceleration now makes this all happen faster and eats up more road in the process. If we are talking straight line cross ups due to ice, that's a little different, but adding speed in the presence of ice does not seem like a good idea to me. (and yes, I've driven on snow and ice)
Old 01-02-2010, 05:14 AM
tseekins's Avatar
tseekins
tseekins is offline
Received 1,221 Likes on 803 Posts
My poor daughter in BFE Illinois driving a 2006 Fusion just had a slight fender bender. She was making a turn (probably too fast) and the front end just kept on going. Her tires are in poor condition to say the least accompanied with her inexperience in winter time driving.
She's coming home to visit later this month and at a minimum, I'm replacing the two front tires. The two next best will go out back if I don't replace all four.
Tim
Old 01-03-2010, 02:05 PM
85e150's Avatar
85e150
Tim
I see your point. Tell me this: Would this accident have been more or less serious if she had hit whatever she hit sideways?
Old 01-03-2010, 02:14 PM
tseekins's Avatar
tseekins
tseekins is offline
That's a good question and I can't answer it. If I'm correct in assuming, I believe your about to make a point about mounting the new tires out back. But, the back end didn't come around. I'm pretty certain that I'll change all four anyhow as she's a newly wed and still poor and now pregnant.
Tim
  #28
Old 01-03-2010, 04:04 PM
Greywolf's Avatar
Greywolf
Greywolf is offline
It's old news that when you have RWD, and the back end breaks loose you can probably drive through it.
If you have front wheel drive, and break loose - if you can't POWER through it you are done
If you have AWD and you get loose - prepare to meet your maker. You've been STUPID and should have known it long before it happened
  #29
Old 01-03-2010, 04:39 PM
1977f150xlt's Avatar
1977f150xlt
1977f150xlt is offline
very true, lol lol lol
also its kinda scary when you have a rear wheel drive Mustang and no snow tires up front, and you apply the brakes and the front end slides side to side! yes the front! it can happen, as the front wheels are where most of the stopping power comes from in a car/truck, thus you would be better off with skis up front!, thus i suggest winter tires on all 4 corners no matter if your vehicle is RWD or Front wheel drive or AWD/4x4, also no matter if you have AWD/4x4 or not, they all stop the same, if you have poor tires then expect to slide, thus i hate these people in these AWD vehicles in the winter, they drive like its summer time!
-Brent
  #30
Old 01-03-2010, 06:07 PM
FoxNotch's Avatar
FoxNotch
FoxNotch is offline
Maybe I'm missing something, but I've had my jeep all over the place in the snow (in 4wd) and its very easy to correct.
Quick Reply: One tire blows out and tire shop wants to change all four!!!
