Shaft seal leaking on front axle - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 12-23-2009, 07:59 PM
gdfrick122 gdfrick122 is offline
gdfrick122 is starting off with a positive reputation.
I have a 2004 F250 4X4 the front axle seal is leaking where the driveshaft goes into the axle. How would I go about changing the seal? Is this an easy job or should I take it to a professional mechanic?
Any advice would be appericiated.
Old 12-23-2009, 09:03 PM
Vijay's Avatar
Vijay Vijay is offline
Vijay is gaining momentum as a positive member of FTE.
Can you give more info? Do you mean where pinion meets the carrier bearing unit? or is the oil leaking onto the tires from the axel shaft/Axel tube.
Old 12-23-2009, 09:34 PM
The leak is where the driveshaft goes into the axel.
Thanks
Old 12-23-2009, 10:36 PM
xd2200 xd2200 is offline
xd2200 is starting off with a positive reputation.
I believe that you are referring to what is a dust seal. Should be no oil on inner side of seal normally. If there is oil leaking then seal at differential end of axle is the culprit. Sometimes if axle vent line becomes clogged the pressure builds up and forces oil through the inner seal and then it goes down the axle tube and then through the dust seal - I would check the vent line first.
Old 12-23-2009, 10:51 PM
Pitch_Black05's Avatar
Pitch_Black05 Pitch_Black05 is offline
Pitch_Black05 is starting off with a positive reputation.
if you rleak is an axel shaft seal its an ok job just kinda a pain to get the axel out u need to taka alot of things apart to get it out. if its the drive shaft it should be even easier u just will need socket big enought to get your driveshaft mounting flage off to get to the seal. if you are new to this prob i would just take it to a shop. if u dont get the seal in there right u will have the problem again. but if u can show us a pic of the problem area we could steer you in the right direction faster
Old 12-24-2009, 09:17 AM
Pic of leaking axle
Thanks for the advice from U guys so far. I can take a picture of the leak but I don't know how to get it on the site so you all can see the problem. Would I upload it to my gallery?
Thanks again and Happy Christmas Eve to all!
Old 12-24-2009, 10:01 AM
SGnAZ's Avatar
SGnAZ SGnAZ is offline
SGnAZ has a very good reputation on FTE.SGnAZ has a very good reputation on FTE.SGnAZ has a very good reputation on FTE.
When you post a reply,go down to "manage attachments" and it will guide you through-very easy
Old 12-24-2009, 01:03 PM
Vijay's Avatar
Ok, I think you are referring to pinion seal. I have not worked on that before and people who worked on it give conflicting reports. Some say it is easy given right tools and other say, take it to shop. But if I were you, I would try first and then take it to shop if necessary. Yours should be a DANA 60 front, so help and manuals are plenty.
Old 12-26-2009, 11:20 AM
Pictures of leaking seal
Thanks for the info everyone.
Please follow the link below for a picture of the leaking seal.
100_0038 on Flickr - Photo Sharing!
Any advice is appericiated.
Old 12-26-2009, 12:08 PM
ok by the look at the pic its the front pinion seal, easy easy fix, all is to remove the drive shaft, and then there is a large nut inside of the yoke, u will need a air gun to remove this nut. then pull the yoke and pull the seal, make sure u replace it with a new one make sure then u put in the new seal it gets installed flush. replace the yoke and make sure the nut is set back to proper torqe spec. and then hook the drive shaft back up and check the fluid level. just remember that this type of leak a little fluid makes a big mess from the moving parts. but it should be a simple fix. good luck
Old 12-26-2009, 12:35 PM
Rongold's Avatar
Rongold Rongold is offline
Rongold is gaining momentum as a positive member of FTE.
Pinion Seal Leak ????
I just looked at your 3 pictures, and I don't see anything leaking. I would leave it alone.
RON
Old 12-26-2009, 02:29 PM
It is leaking
Sorry Ron, I wiped the leak up around the shaft seal before I took the pictures. My mistake. The way I spoted the leak was I was driving the truck in 4X4 low for a while to warm up the oil becaus the other day I had plans on changing the oil in the front axle. This is when I spotted the leak. It only leaks when in 4X4.
Thanks,
Old 12-26-2009, 10:33 PM
Thanks everyone for all the advice. I'll get a seal Monday change the seal and go ahead and change the dope in the axel.
Old 12-26-2009, 10:39 PM
senix's Avatar
senix senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
easy fix lock your hubs in before you do it to help hold that axle from turning. when you tap the new seal in place take your time to tap in evenly.
FRONT AXLE DUST SEAL??? RIDE RED Modular V10 (6.8l) 9 08-09-2012 04:57 PM
1994 f150 rear axle thehulkster012 1987 - 1996 F150 & Larger F-Series Trucks 3 04-02-2012 07:24 AM
LET'S TALK ABOUT PINION SEALS AND HOW TO REPLACEMENT THEM F1004x4Owner 1961 - 1966 F-100 & Larger F-Series Trucks 29 11-27-2011 11:12 PM
Front Axle Seals dmartinez21 1999 to 2016 Super Duty 12 07-26-2010 02:57 PM
front inner axle seal ? n20 1999 - 2003 7.3L Power Stroke Diesel 19 03-01-2010 10:30 AM
Tags
1997, 2006, 4x4, axle, dust, duty, f250, f350, ford, front, leaking, replace, seal, shaft, super
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
