More power out of a 5.4 Triton - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 12-23-2009, 06:41 PM
dfboothe dfboothe is offline
dfboothe is starting off with a positive reputation.
i've got a f250 with a 5.4ltr, and 4.10's, what can i do to get more horsepower/torque out of it? thanks for any help
Dylan
Old 12-23-2009, 07:15 PM
bbender85's Avatar
bbender85 bbender85 is offline
bbender85 has much to be proud ofbbender85 has much to be proud ofbbender85 has much to be proud ofbbender85 has much to be proud ofbbender85 has much to be proud ofbbender85 has much to be proud ofbbender85 has much to be proud ofbbender85 has much to be proud ofbbender85 has much to be proud of
what year???
EDIT: if it's the '99 listed in your profile, get some OEM Power Improved cams for it; i've done your typical intake/exhaust/tuner on my '99 and it was a little help, but not a huge improvement... cams are on my to-do list this winter before it's trailer haulin' season again.
Old 12-23-2009, 07:22 PM
yeah it's a 99,
cams from Ford? i didn't think about that
Old 12-23-2009, 07:27 PM
bbender85's Avatar
you can find take-out stock cams on ebay from time to time for cheap. and being an OHC engine... it should be a fairly easy install.
Old 12-23-2009, 08:45 PM
spinella's Avatar
spinella spinella is offline
spinella is a splendid one to beholdspinella is a splendid one to beholdspinella is a splendid one to beholdspinella is a splendid one to beholdspinella is a splendid one to beholdspinella is a splendid one to behold
Old 12-24-2009, 02:29 AM
redford's Avatar
redford redford is offline
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
The answer to your question depends on how much money you are willing to spend on your truck.
Cam change, better exhaust, a better manifold and cold air box will help some.
Nitrous Oxide, a turbocharger or even a supercharger would give you a large power boost.
Want more? Maybe a 605HP 4V crate engine from SVO would do it for you?
Ford Racing Romeo 605 HP Performance Crate Engine 5.4L 4V w/TVS Supercharger [M-6007-TVS] - $17,229.95 : Powered By Ford - Your only high performance parts supplier for your Ford car or truck, When you want it done right and done well there is only o
But, realistically, a few minor engine mods and a gearing change in the differential are probably all you need.
Old 12-24-2009, 05:06 AM
TexasRebel's Avatar
TexasRebel TexasRebel is offline
TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.
the easiest answer is:
put your foot down...
Old 12-24-2009, 06:54 AM
spinella's Avatar
thats good, don't know how i overlooked that.
Old 12-24-2009, 08:13 PM
TexasRebel's Avatar
yikes!
I just looked up a few cams for these engines...
I've rebuilt entire longblocks for less...
Old 12-24-2009, 10:14 PM
ken kenmnedy's Avatar
ken kenmnedy ken kenmnedy is offline
ken kenmnedy is gaining momentum as a positive member of FTE.
I got a set of comepleat PI heads with cams and intake and hole motor [cracked block)
Old 12-24-2009, 10:28 PM
yeah tuner is first on my list, saving up for it now,
new engine is prolly on the extreme side,
i like the put your foot down option, i do that from time to time to remind myself is a FORD, and will haul a$$
Old 12-24-2009, 11:14 PM
1975StroppeBaja's Avatar
1975StroppeBaja 1975StroppeBaja is offline
1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold
A gear ratio change would probably give you the most bang for your buck. Go up to 4.30 or 4.56 and that'll help the feel of the truck.
Old 12-25-2009, 12:03 PM
ClintD1's Avatar
ClintD1 ClintD1 is offline
ClintD1 is starting off with a positive reputation.
What year did the triton 5.4 come with PI heads?
I didn't know this even applied to the SD trucks. I'm only used to the 4.6 NPI / PI car engines.
got a nice 32valve 4.6 for a ranger project I'm doing, but that's another story.
Old 03-26-2010, 06:45 PM
2dub 2dub is offline
2dub is starting off with a positive reputation.
Well ... just got the truck back today ...
Finally got the Gear change 3:73 --> 4:56. Some said "wow, thats steep" some said "you'll love it, another said "you're gona hate that thing on the highway" .... I definitely feel the difference, not sure what I was expecting...still a bit tough to spin these 35s on pavement
Satisfied, for now ... another 2k spent and got a little pep, but still searching for more pull...
Old 03-26-2010, 06:54 PM
Fordfanatic4life Fordfanatic4life is offline
Fordfanatic4life has a very good reputation on FTE.Fordfanatic4life has a very good reputation on FTE.Fordfanatic4life has a very good reputation on FTE.Fordfanatic4life has a very good reputation on FTE.
shame you didnt go to 4:88's...
your comnig from the same gears i have and spinnin the same size tires i do.. i would go 4:88's for 35"s..
it puts you above the stock gearing numbers when you balance out the bigger tires..
going to 4:56 puts you back about where the truck was stock
still now that your done with the regear, you can do the tuner and i bet that will liven up your truck nicely.
p.s. repost with some mileage numbers after a few tanks if you dont mind comparing before and after teh regear.
Anyone do 5.4 performance upgrades? Dodge no more 1999 to 2016 Super Duty 34 08-22-2016 12:31 PM
99 5.4 triton spark plug ? riverking 1999 to 2016 Super Duty 7 08-24-2014 07:55 PM
expedition 5.4 blown engine... Josh Davis Expedition & Navigator 1 02-23-2012 05:14 PM
351w head on 5.4 possible?? roostnu074 1999 to 2016 Super Duty 18 01-09-2009 06:58 PM
200a sd 5.4 tjpye Modular V8 (4.6L, 5.4L) 6 09-16-2007 09:29 PM
Tags
2000, 2004, 4v, 54, 54l, add, crate, engine, f150, f250, ford, forums, heads, horsepower, power, powerout, stock, supercharged, triton
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
