1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
CAT engine in SuperDuty. What??????
Old 12-23-2009, 05:35 PM
A H DEVELOPMENT's Avatar
A H DEVELOPMENT
A H DEVELOPMENT is offline
Question CAT engine in SuperDuty. What??????
The other day I was talking to this guy about my truck at a tire supplier/warehouse. The first question out his mouth was what engine you got in there 6.0, 6.4, or a CAT. I responded 7.3 with a funny look on my face. He said you know some guys are puttin' CATs in these trucks. I responded really??? He said yep, you know those CAT engines are so heavy when they put them in the front ends of these truck that they can't even go off-road cause they'll get stuck, even in the grass. The conversation ended and I walked away not really knowing if I should believe what he said. However, I do know that some Big Rig truck owners have elected to replace their engines with CATs instead of stock replacements. So can you really put a CAT in a SuperDuty and if so what model CAT??????
Thanks for your response.
Old 12-23-2009, 06:30 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
weekendwarriorfsw32 is offline
Master of Strokes
Sounds awesome but never seen one.
Old 12-23-2009, 06:35 PM
Vijay's Avatar
Vijay
Vijay is offline
The smallest engine from CAT (highway) is a C 7 ( 7.2 Liter), but I doubt that you can fit a CAT under F 350-550 base. The engine is pretty big in size and about 1500 pounds. A 7.3 Liter measures about 1000Lbs, if weight is not a concern the dimensions is another story...
Old 12-23-2009, 06:39 PM
Vijay's Avatar
Vijay
Vijay is offline
Also, note that CAT is doing away with their highway engines due EPA norms...
Old 12-23-2009, 08:20 PM
Pinky Demon's Avatar
Pinky Demon
Pinky Demon is offline
Grrrr.....
Old 12-23-2009, 09:01 PM
texastech_diesel's Avatar
texastech_diesel
texastech_diesel is offline
Token Redneck
The 7.2L C7s were an option in the 650/750 series trucks, alongside 6.0L PSDs and 5.9L Cummins up to 2007. In 2009, the 6.7L Cummins and 7.2L CAT are available. They come with a pretty good selection of power setups to match the gearing and chassis type.
Ford F650 Engine Specs, Ford F750 Engine Specs, Ford Engine Specs - Meadowlands Ford-Sterling Company Profile. 330 County Ave, Secaucus NJ
https://www.fleet.ford.com/showroom/.../2009-f650.asp
Old 12-24-2009, 01:42 AM
redford's Avatar
redford
redford is online now
Received 1,562 Likes on 910 Posts
If you go back and tell him you can't get a Cat is an F-250 to F-550 chassis he will swear he has seen one before.
I used to work next door with the guy who installed a Detroit Diesel in an old F-350 chassis (an old 4-71 inline if I recall correctly) used to run around the Ballard area of Seattle a few decades ago. Some swore it was a factory install, but if you asked the guy he would tell you he put it in. Those old Detroits were 2 stroke diesels and had a very distinct sound at idle.
Old 12-24-2009, 08:47 AM
F250Wheels's Avatar
F250Wheels
F250Wheels is offline
I knew of a couple of 3208 V8 cat motors in 1 ton fords, that was years ago.
Old 12-24-2009, 12:10 PM
Vijay's Avatar
Vijay
Vijay is offline
I would love to see one F350/450/550 with CAT in it...CAT engines last for ever.
Old 12-24-2009, 01:54 PM
shore's Avatar
shore
shore is offline
I always thought it would be cool to cram an old 3408 in a Superduty. It would probably take a "little" modification of the engine bay, but it could happen.
Old 12-24-2009, 01:57 PM
Vijay's Avatar
Vijay
Vijay is offline
With CAT on a F 350-550, oil change would be a fullblown circus, the filter is on a side!!!!
Old 12-24-2009, 02:19 PM
99F-350CrewCab's Avatar
99F-350CrewCab
99F-350CrewCab is offline
Anyone have the weight and dimensions of the stock 7.3?
http://ohe.cat.com/cda/files/378795/...%20P1.pdf?mode
Old 12-24-2009, 03:55 PM
rmosso1's Avatar
rmosso1
rmosso1 is offline
You gotta be kidding me. A Cat 3408 in a F-450, F-550, F-650?
The last 3408 I saw was in a 988B I bot brand new. You can check what a CAT 988B loader can do. The s/n of the machine I bot was 50W 4001.
This was years ago, but I will tell you that none of the trucks mentioned above could haul the engine. I vividly remember the machine bot was produced on a Friday in a strike year, and blew its nose after two weeks against a high wall.
We all have visions. Maybe you meant a 3208.
Old 12-24-2009, 04:49 PM
Vijay's Avatar
Vijay
Vijay is offline
Approx 1000Lbs, CAT C 7 is 1500Lbs
Old 12-24-2009, 06:05 PM
conger's Avatar
conger
conger is offline
I've seen quite a few Cummins swaps in SD's in Diesel World mag. Nothing on a Cat diesel. I didn't think they made anything small enough to fit. I think it would be an interesting project.
Quick Reply: CAT engine in SuperDuty. What??????
