I am aware that you pull that little metal tab out, but even with that done and me pulling on the arm it won't come out. I am going to replace my noisy wiper motor and I need to take the cowl panel off. How do I get the wiper arms off? The truck is a 1989 ford f150.
pull the arm away from the wind shield and look down where it attaches to the motor rotating thing and u will see a little clip pull it out.. ok then u can let the wiper go and it wont touch the windsheild
If you pull the wiper arm up off the window as far as it will go, pull the little tab out and let the wiper arm spring back against the tab so it stays, then you'll be able to lift the whole arm off the drive spline with a little wiggling.
lol im srry bout this but since this is about windshield wiper stuff has any one here used these
i have used the bosch ones like these on the other truck i had and im wanting to know if any one here used them
