Ford security system button?
Fellas,
Just bought an 08, and it's got a wierd button near the bottom of the plastic below the steering wheel. I traced the wires to a box that said ford security sytem... I noticed it's never lit up, but when i pressed the button, and then turned off the engine and locked the doors, the led glowed red.
Does anyone have more information on this? what is is and how well it works?
The botton is the same as I have in my 6.4 PSD with the Ford security system. When you unlock the entry door with the FOB you will have about a minute to start the engine. After this time, the ignition key will not start the engine. Turn the key to ON then press the button and then the engine should start when key is rotated to start.
The last four Ford Vehicles I have had came with the security button with the Ford Secured System. The button is usually located under the dash near the steering column or on the side of the left kick panel.
THANKS! works as described. Appreciate the info!
GRUBBY604
Electrical Systems/Wiring
05-10-2014 06:32 PM
geckocub69
1997 - 2003 F150
06-28-2007 08:34 PM
jlitz
03-16-2004 11:51 PM
