how to find gear ratio on dana 44 front
Old 12-04-2015, 11:29 AM
Jacksalander's Avatar
Jacksalander
Jacksalander is offline
Would you be able to look up my gears?
Originally Posted by Ford6.02005
After 10 years working in a 4x4 specialty shop and saving a set of Spicer books from that era I still look them up the old fashioned way-you may want to try www.spicerparts.com and navigate your way through their site...or If you post your BOM#'s I will be glad to look them up!
I have a Dana 44 from a 79 bronco that I'm using for a project. I was told it has 3.50 gears but I wanted to be sure of it. My Bom tag says 610067-2
Old 12-04-2015, 07:32 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,585 Likes on 1,292 Posts
Just count the teeth on the ring and pinion. You can probably just count the ring, and spin it a couple times and figure it out.
Combo's listed here:
Richmond Gear Dana Ring & Pinion Sets | Richmond Gear
If the Bronco had 3.50 gears in the Ford 9er out back, the closest Dana ratio is 3.54, so that's what you are looking for, at least initially.
Old 12-04-2015, 11:39 PM
Ford6.02005's Avatar
Ford6.02005
Ford6.02005 is offline
Ratio Formula
Using the 42/12 shown on the ring gear the ratio comes out to 3.50...
Old 12-05-2015, 12:50 PM
Jacksalander
The last two numbers on the ring gear show the ratio? What's the equation for finding it?
Old 12-05-2015, 12:51 PM
Jacksalander
Never mind. That was a dumb question.
Rustyol79
08-14-2017 03:20 PM
wildcard221
02-15-2017 06:23 PM
olblue77
10-17-2016 04:19 PM
LosOsos
05-25-2016 03:01 PM
Bubba Jones
1978 - 1996 Big Bronco
18
02-14-2016 11:04 PM
Quick Reply: how to find gear ratio on dana 44 front
