8.8 LSD F150 exploded view diagram? - Ford Truck Enthusiasts Forums
Old 12-23-2009, 01:59 PM
konasexone konasexone is offline
konasexone is starting off with a positive reputation.
I'm looking for an exploded view of my 8.8 LSD . How many bearings on the pinion shaft? Is there a front one I can get at easily? My Haynes manual doesn't help me here.
Old 12-23-2009, 04:55 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
not exactly , but this will give you an idea of how its made.
Google Image Result for http://z.about.com/d/autorepair/1/0/H/A/42122782.gif
Old 12-23-2009, 04:58 PM
steve(ill)'s Avatar
the pinion slides in from the rear with 1 bearing, you tighten the crush nut on the front to hold it in and set preload. the ring gear bolts to the planet gear holder, and the clutch pack sets to the side of that... in the photo, you can see the cluthc pack housing.
Old 12-23-2009, 07:14 PM
Thanks. There is also a front bearing which I think can be changed without pulling everything apart. My diff also has a wave spring in it.
crashed my ranger in a concret wall on the hwy & my rear axle shaft is crooked... reggiedunlop Ranger & B-Series 7 12-22-2016 09:19 PM
Front lsd install?? Marcof150 1997 - 2003 F150 3 07-01-2016 02:18 PM
winter fun with 6.0 powerstroke Aleks Riga 1999 to 2016 Super Duty 2 01-16-2016 08:38 AM
What 8.8s will swap directly? patrickj20 1987 - 1996 F150 & Larger F-Series Trucks 2 12-09-2015 07:57 PM
Switching to a LSD carrier, what should I look for? trekalltop Ranger & B-Series 1 02-12-2015 07:51 PM
Tags
2001, 2003, 40, 88, diagram, differential, exploded, explorer, f150, ford, front, lsd, motor, truck, view
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
