351W to 460
on
Yes.. but it really depends what you use the truck for. If it does a lot of heavy hauling then go for the engine swap, the 5.8 can be significantly improved relatively easy but it isn't going to produce big block torque without a stroker kit and a pile of money.
well in that case i would plan on a gear change. this will give you your biggest impact performance wise. for running 38's figure at least a 5.13 gear set front/rear. you could probably go with these gears now and be ahead of the game. Which tranny do you have? if you have the E4OD then you for sure want to regear before you go to that size of tire because even with the 4.10's it will kill the tranny.
upgrading the exhaust is a great start and does help the 5.8
bronzo
23
04-30-2003 06:38 PM
Jimbare
09-03-2002 08:37 PM
