Go Back   Ford Truck Enthusiasts Forums > Misc. > Offroad & 4x4
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Offroad & 4x4 SPONSORED BY:
  #1 (permalink)
Old 12-23-2009, 01:34 AM
none2 none2 is offline
Garage is empty, add now
none2 is starting off with a positive reputation.
Fender trimming for bigger tires? good idea or bad?
Hi all! I've a 2003 7.3L PS F250. I'd like to get some larger tires, I've got 33" on there now. I would also like to maintain some wheel travel for off roading.
What are the cons to triming the fender walls to fit larger tires VS a lift ?
Anyone know how much fender I can safely trim from a 2003 F250?
Thanks!
__________________
2003 F250SD, 7.3L diesel, FX4
  #2 (permalink)
Old 12-23-2009, 01:52 AM
chrono4's Avatar
chrono4 chrono4 is offline
chrono4 is a name known to allchrono4 is a name known to allchrono4 is a name known to allchrono4 is a name known to allchrono4 is a name known to allchrono4 is a name known to all
Pro's
-maintain a stock ride, other than the offset of the added unsprung weight of the bigger tires
-won't have to deal with sorting out drivetrain issues from increased driveline angles
-it's cheap
-imho it looks better than a lift
Cons
-you've got to cut the fenders up on a nice pretty truck
-you can only go as big as you can cut without hitting things (which is almost always more than people would want), like body mounts, inner fenders ( unless you move them up) ect.
I'm sure there's more to both of those lists, it's just a start there.
__________________
--Andrew--
Rocking a 79' f150 with a 300 and a 4 speed........
Full York OBA Install
Welding a 9"
Very simple front bumper
Lowering Spring Towers
Hi, I'm Andrew and I have a wheelin problem that is often disrupted by fabbin and drinkin, glad to meet yall.
STGs MinionsTechnical Advisor
  #3 (permalink)
Old 12-23-2009, 02:12 AM
75F350's Avatar
75F350 75F350 is offline
1973 Ford F-100
My Garage
75F350 is a name known to all75F350 is a name known to all75F350 is a name known to all75F350 is a name known to all75F350 is a name known to all75F350 is a name known to all
Additional lift for these trucks are easy and not all that expensive.
The biggest advantage that you will achieve with a "real" lift is added articulation. Notice how close the bumps stops are to the frame up front. This only allows a few inches of up travel at best.
Tires alone will only gain minimal amounts of lift, and will do nothing for additional performance.
A true lift will provide you with more advantages than cutting the fenders will ever provide.
Increase travel and you will have a far better performing truck.
  #4 (permalink)
Old 12-23-2009, 02:22 AM
chrono4's Avatar
small correction. bump stops being close don't inhibit travel, only compression. travel is overall droop+compression from ride height.
Good points, and for the most part, overall true. Fender cutting comes as a personal choice, and when it comes down to keeping the COG down for crawling. Guessing you're not doing much of that in an 03 PSD though ha
__________________
--Andrew--
Welding a 9"
  #5 (permalink)
Old 12-23-2009, 07:23 AM
Blue Rebel's Avatar
Blue Rebel Blue Rebel is offline
Blue Rebel is gaining momentum as a positive member of FTE.Blue Rebel is gaining momentum as a positive member of FTE.
40s and only a 4" lift on an 05. Trucks a powerstroke also:
Click the image to open in full size.
__________________
1989 F250 4x4, 351W, ZF S542, 4:10s, Upgraded to Dana 50 TTB front, 4" suspension lift 33" street, 38" swampers for when things get crazy!
1995 F150 4x4 Swapped in 351W MAF, 4r70w auto, 6" suspension lift, 35" tires, 4:10s, Daily Driver
1993 F350 4x4, 7.3L N/A, ZF S547, 4:10s
  #6 (permalink)
Old 12-23-2009, 03:59 PM
Prozon's Avatar
Prozon Prozon is offline
1988 Ford F-350
Prozon has a good reputation on FTE.Prozon has a good reputation on FTE.
I think the biggest CON would be, well your hacking up your ride! If you don't do it good, then you'll have a ****ty looking fender.
I've seen lots of people jump right into cutting the fenders, and they came out looking like crap.
Then again, there have been a lot of people who have done this good and it looks awesome.
It can go either way..
__________________
Quote:
Originally Posted by fatdan460 View Post
wtf? you don't post in forever and then when you do i see that i'm not quoted in your signature anymore. i r sad
  #7 (permalink)
Old 12-23-2009, 10:28 PM
chrono4's Avatar
If it does come down to trimming fenders, a good sharp air nibbler, some masking tape, and making sure you have a good wheel well line goes all the way.
__________________
--Andrew--
Welding a 9"
  #8 (permalink)
Old 02-25-2010, 03:27 PM
Truckin4life Truckin4life is offline
Street Queen to the extr3m3
Truckin4life has a great reputation on FTE.Truckin4life has a great reputation on FTE.Truckin4life has a great reputation on FTE.Truckin4life has a great reputation on FTE.Truckin4life has a great reputation on FTE.
Ed i have to disagree with part of this, you can lift a truck 8" and put 35"s on it and blast through the mud, but your diff is still only2-3" farther off the ground, everytime i get stuck the axles are burried in the mud, a few times i have set the frame down in the mud too, had to climb out my window a few times too.
But a lift will only make more space between the body, components, and frame to the ground. The tire size is where you really gain clearence. If your dragging your front axle through the mud, it will eventually plow up and you will be stuck...
Now when you run 44" boggers and enough power to rip honda's in 2. Your on another playing field...
That kinda power and that size of tire, you can get through alot of chit...
That being said....
Lift the truck. I am not against fender trimming, i have done it.
But Ed brings up good points. You wont get as much suspension flex from a fender trim as a good lift...
__________________
Don
I like bacon.
Quote:
Originally Posted by captain p4 View Post
chuckstrucks brings the lols and make cheeto look like a genius.
  #9 (permalink)
Old 02-25-2010, 03:55 PM
82F100SWB's Avatar
82F100SWB 82F100SWB is offline
82F100SWB has a good reputation on FTE.82F100SWB has a good reputation on FTE.
A 35 and a little bit of trimming on a S/D doesn't look or work bad at all, There's lots of room height wise on them, it's just the front and rear of the wheel well that's tight towards the bottom. That said, a small lift doesn't look bad at all either.
A 4" lift and 35's goes together very nicely on uncut fenders on a S/D, but as you can see above, trim the fenders and 4" is a HUGE amount of room.
__________________
96 F350 Crew Psd/5 speed,/4x4... $600 special
96 F250 XLT PSD/5 speed/4x4... Freebie!
92 W250 LE, 4x4/CTD/G360/D60/D70U
86 F250 HD 4x4, 6.9/T19/broken D44 TTB junk/10.25.
8? F100 4x4 Mild 460/T19 D60/welded 10.25/44 Boggers,
It's not what you BUY, It's what you BUILD
  #10 (permalink)
Old 02-25-2010, 03:58 PM
alpha/omega's Avatar
alpha/omega alpha/omega is offline
alpha/omega has a great reputation on FTE.alpha/omega has a great reputation on FTE.alpha/omega has a great reputation on FTE.alpha/omega has a great reputation on FTE.alpha/omega has a great reputation on FTE.
35s on a stock 04 F250 doesnt look or work bad at all
__________________
Quote:
Originally Posted by Bootzz711 View Post
I don't have a ttb axle I have a Dana
Quote:
Originally Posted by A1C DiMaggio View Post
i wish i could afford thornbirds...plus they are too aggressive for my needs
Quote:
Originally Posted by Carlene
It just gets me all hot & bothered when you tech talk. hahahaha
Quote:
Originally Posted by H.S. Thompson
Buy the ticket, take the ride
  #11 (permalink)
Old 02-25-2010, 03:59 PM
That truck posted earlier looks SWEET!
36"s on a stock 250 with some sheet metal removed looks nice!
__________________
Don
I like bacon.
Tags
1988, bad, big, bigger, cons, cutting, f250, fender, fenders, fitting, good, larger, tires, trimming, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
