How to remove the key cylinder? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 12-22-2009, 09:13 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32 weekendwarriorfsw32 is offline
Master of Strokes
weekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud of
Hey everyone,
Like the title says how do you remove the key cylinder on a 01 Ford Excursion.
Thanks
Nick
Old 12-22-2009, 09:20 PM
wallz's Avatar
wallz wallz is offline
wallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud of
Nick, there is a small hole in the plastic cover under the switch. With the key in the ignition, in the run position you need to use an awl(or similar) and push in a small spring as you pull the cylinder with key out.
how to remove ignition key cylinder MONAVIERONJON 6.4L Power Stroke Diesel 1 08-27-2016 04:29 PM
2008 Expedition ignition cylinder came out with key bgwho922 2007 - 2014 Expedition & Navigator 2 07-13-2016 09:51 AM
2002 explorer ignition lock replacement indymike Explorer, Sport Trac, Mountaineer & Aviator 5 12-08-2012 09:18 PM
ignition cylinder removal Poison Oil Racing 1973 - 1979 F-100 & Larger F-Series Trucks 4 01-20-2009 09:50 PM
Lock Cylinder Removal?!?!? B-DOGG Ranger & B-Series 5 03-19-2006 02:10 PM
Tags
2001, code, cylinder, cynlinder, disarm, duty, f150, f250, f350, ford, key, location, remove, super, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
