Brake problem
Brake problem
I have an 04 350 SD 6.0 and have noticed that occasionaly when i brake i have firm pedal feel and then there is like a 1-2 second gap when my brake pedal goes soft and there seems to be no braking going on. I took it to Les Schwab and they are going to check it out tomorrow and that it might be the vacuum pump or the master cylinder. Does anyone have any idea how much this might cost to fix. Also i have noticed that the ABS light turns on and stays on when i start the truck, then the next time it won't. Any insight would be much appreciated !!!!!!!!!!
Thanks,
Frits
Thanks,
Frits
