You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Here is my project truck. My goal is to turn it into a good ole' Redneck Camo Hunting Truck and bad weather truck.
It needs the following:
1- Short in the brake lights needs fixing
2-Tune up (oil change, oil filter,check all fluids, radiator flush, new plugs & wires, new belts, and new distributor)
3-Butterfly valve is missing so the carburator needs work and is missing some vacuum hoses.
4-Flowmaster 40 single inlet/dual outlet and tailpipes
5-Needs 5 new tires. My goal is to add 31x10.5x15 tires, but not sure I can afford it.
6-Needs a little bondo work in the rear fender wheel
7-New wiper blades
8-New radio and & CB and antenna
9-Remove spare tire holder from under truck
10-Various tubes & hoses in engine are cut, so I need to fix them
11-Camo Seat cover
12-Camo Headliner or maybe use Herculiner
13-Remove the ripped up rubber floorboard covering and use Heculiner
14-Camo Paint Job
15-I need to pick up a Haynes Manual.
16-Herculiner Bed
17-Lap belt needs replacing. Its got a big tear in it.
