Missing Hoses & Tubes Broken
#32
OK sounds good. I should be done soaking and cleaning the parts by tomorrow morning. Several were coated with thick dirt, grime and carbon so I've had to soak them for a very long time. I took the other carb off the truck last night in preparation for the switch. I noticed the looseness wasn't coming from the carb, but from the piece of equipment that the carb sat on. There is something sitting on top of the intake and the carb sits on top of it. Hopefully it'll tighten up, but the bolts from the carb were on pretty tight to begin with.
#33
#34
Unfortunately, I didn't pay much attention to the wiring. I popped the hood and almost the entire engine was gone. The block with Valve cover, distributor and plug wires were still there. The carburetor was actually sitting in the truck cab. Easiest pick-n-pull I've ever done. I'll go back there next week and look for the wiring harness, but I' doubt its there.
#38
Ok, before I decide which direction I want to go, here are some more pictures of the nonfeedback carb. Can you look at it and tell me if it is missing anything?? I can get the butterfly valve from the feedback carb, but not sure if it is missing anything else.
If its not missing too much, it'll probably be cheaper to switch over to duraspark. My fear with the junkyard carb is if those sensors don't work it'll get real expensive replacing them.
#39
#41
for the duraspark conversion, wireing harness is different, get the one that comes with the distributer, and the box. it's plug and play though, you don't have to change connections. if you go with the hei, you use the harness that comes out of the distributer you get from the junk yard, make sure to mount the hei modual on a piece of aluminum , so it cools, you need to put dielectric grease between it and the modual.
#42
If you decide to get a new distributor, consider our custom curved Duraspark Distributor built with our new Full Length Oil Impregnated Bronze Bushing. The full length bushing improves timing stability and spark scatter. If stock appearance is not an issue, take a look at our one piece D.U.I. Distributor. Whether you choose the Duraspark or the D.U.I., we curve each on a distributor machine based on your engine combination. Please see them at:
http://performancedistributors.com/forddistributors.htm
Also, there is now an excellent installation article on the D.U.I. Distributor on the Ford-Trucks.com site at:
https://www.ford-trucks.com/article/idx/0/358/article/DUI_Ignition_Installation_In_A_Ford_351W_V8.html
Ignition Lesson of the Month: Hystereses, the difference between the timing as the rpm and vacuum increases to the timing as rpm and vacuum decrease, needs to be kept to a minimum. A precise advance curve accomplishes this.
__________________
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
FTE Sponsor
davewild
349
08-30-2020 10:17 AM
