British Columbia British Columbia
Join Chapter, Leader: sky Cowboy
Tire Sizes!?
Old 10-31-2009, 01:25 PM
Ehkart's Avatar
Ehkart
Ehkart is offline
Tire Sizes!?
So I'm going to need to get new tires for the '91 F250 Diesel soon. I've found that it is equipped with 235/85R16, and I would like to get something maybe a little beefier. Not alot bigger mind you but just a little wider and a tough grip so if I want to I can get anywhere with it. I'm confused as to what I need to do about size differences and my speedo/odometer readings. I've read you just have to keep the overall diameter the same but then how is it that you can put 44" tires on then? So what do I do?
Old 11-01-2009, 05:11 PM
BC Wrecker's Avatar
BC Wrecker
BC Wrecker is offline
I have heard you can buy speedometer correctors for use when putting non stock size tires on your truck. Back in the cable driven days, which a 91 might still be.. idk, there was just a plastic? gear on the end of the cable that you could buy with several different tooth counts to help get your speedo accurate again. Better to get one off a parts truck instead of at the dealership... they wanted $42 for the last one i inquired about!!
Old 11-02-2009, 05:38 AM
Zip's Avatar
Zip
Zip is offline
I have heard of those as well.
Old 11-02-2009, 10:51 PM
Ehkart's Avatar
Ehkart
Ehkart is offline
Hmmm, interesting to say the least. I'll look into this; the father in law says hes pretty sure there should be a Gain control right on the transmission, ever heard of that?
Old 11-02-2009, 11:17 PM
Zip's Avatar
Zip
Zip is offline
Can't say I have ever heard of that.
Some tuners have adjustments for tire sizes but probably only for newer ones.
Old 11-03-2009, 08:33 PM
BCHauler's Avatar
BCHauler
BCHauler is offline
Does the 91 have a digital odometer like the 92-96 trucks?
Old 12-30-2009, 08:06 PM
sweetjustice's Avatar
sweetjustice
sweetjustice is offline
My '88 F250 needed the little nylon driven gear replaced. A stock one was about C$25, but you can definitely find them on the net cheaper and with different tooth counts. I believe the stock one was pink with 21 teeth, but don't quote me on that.
Also, I'm also looking for different tires tires. My stock rims are 6" wide, which seems to mean (at least at tirerack.com) that a 235mm tire is the widest they will accept.
aerohiwaystar
Aerostar
15
05-07-2015 02:26 PM
Apocalypse
07-03-2014 11:19 PM
bionicduck
2004 - 2008 F150
19
08-09-2012 09:32 PM
mncowboy969
2004 - 2008 F150
10-24-2008 04:33 AM
none2
Offroad & 4x4
08-31-2005 08:25 PM
Quick Reply: Tire Sizes!?
