4.9 manifold leaks
4.9 manifold leaks
Ok so my exhauste has a bad look so i'm going to re seal it i've gotten to the point where i need to take the dam smog pump off and the egr tube off, but i'm stuck cause the smog pump bolt sits right next to the pulley so i cant get the pump off and i dont know how to remove the pulley with out damaging it, the 3 pulley bolts are removed but i just dont know how to remove it HELP SOS. Also have no idea how i'm going to get that egr tube off i'll post pics later but any help is much appericated.
First off,you have to let us know what you have.Year,EFI? F150? I don't know on the pump pulley,never took one off,maybe some type of puller?Someone on here will know.On the EGR pipe,I've had mine off.Soak the crap out of it with PB Blaster,let it soak and every little while,jar the nut with a few light raps with a hammer,don't beat it up,you just want to disturb the rust a little,you may have to heat it up a little.My top fitting came loose pretty good,the one to the exhaust was terrible,I ended up putting a big end wrench on it and running a block on my floor jack and jacked a lot of pressure on it,then let it set all night,the next day I put more pressure on it (pissed off) and it came loose.I have a '96 F150 with EFI,and had to pull the intake for a leak at the head and the EGR pipe ran through the intake runners,so it had to come off.I have heard of guys cutting them and connecting them some how with pipe,maybe someone on here has an idea on that.By the way,welcome to a great forum!
yeah well its a 94 and i ended up geting the smog pump off and the alternator braket off, cept i ended up f**king my fing up no i got 5 stitches down my finger argh dam fords lol. But tonight i'm planing on soking that pipe with pb tonight. You said you have changed your exhauste manifold gasket did it fix you leak?? just wondering i've herd back and forth results about changing these gaskets.
I just changed the intake gasket,I left the exhaust right where it was,as it was not leaking.They sell a single intake gasket for these.Sorry to hear about your finger,damn that hurts!I would search this forum for manifold gaskets,should be some good info,as I have read many similar problems on here.The EFI's have bolt set ups to hold the exhaust manifolds in place while you put on your intake,so they are easier to install than the whole thing together like the older carb versions.Be sure to get that heat shield in between,it's important,it keeps the heat off your fuel rail and stops vapor lock.Who ever designed that EGR tube to go through everything should have been kicked in the nuts.Good luck with that finger!
TexasGuy001
09-21-2005 06:22 AM
