Motorcraft Diesel Exhaust Fluid (DEF) - Ford Truck Enthusiasts Forums
Old 12-22-2009, 12:43 PM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt Parts Guy Wyatt is offline
Former Vendor
Parts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud of
<TABLE class=main_content><TBODY><TR><TD class=header07>Subject:
</TD><TD colSpan=3>COMING SOON - Motorcraft Diesel Exhaust Fluid (DEF)</TD></TR><TR><TD colSpan=4></TD></TR><TR><TD colSpan=4>The following information is provided to prepare Dealerships for the launch of the new 6.7L Diesel engine in the 2011 F-Super Duty. A more detailed communication will be released in January, 2010 once the new Motorcraft Diesel Exhaust Fluid is released for ordering.
WHAT IS DEF?
A non-hazardous clear fluid (67% deionized water / 33% chemically pure Urea) that is injected into the diesel exhaust system to reduce NOx emissions.
WHY DEF?
  • Required for the 2011 model year F-Super Duty 6.7L Ford diesel to meet 2010 EPA emission regulations
  • For use with competitive make vehicles using a SCR (selective catalytic reduction) system
  • The majority of diesel (light and heavy duty) manufacturers will use DEF to meet the new requirements
</TD></TR></TBODY></TABLE>
FAQ
Why use Motorcraft DEF?
Motorcraft DEF is API certified, meeting ISO22241, and is the only fluid approved and recommended by Ford Motor Company. Inferior product may result in costly damage to the SCR system. System damage as a result of inferior fluid is not eligible for warranty reimbursement.
How is the vehicle filled with DEF?
The fluid is supplied through a fill port located next to the diesel fuel fill port; it has a blue cap clearly marked for diesel exhaust fluid.
What is the capacity of the vehicle DEF tank?
The DEF tanks have a five to six gallon capacity, depending on the vehicle configuration.
How frequently will DEF need to be replenished?
The system is designed to last approximately 7,500 miles between fill ups, coinciding with the oil & filter change interval. However, depending on customer use, replenishment may need to occur more frequently.
Is there a DEF tank level gauge?
The vehicle instrument cluster will provide indication of fluid level in the DEF tank, as well as provide warning messages when the DEF is low and needs to be refilled.
Can the vehicle be operated without DEF?
The vehicle will not operate properly without DEF. When the vehicle DEF monitoring system detects no DEF is available, the vehicle initially goes into a speed limiting mode and then progresses into an idle only mode.
How should DEF inventory be stored?
DEF should be stored out of direct sunlight in temperatures between 23F and 86F (-5C and 30C)
  • Freezing point is 12F (-11C)
  • Prolonged storage at higher temperatures will cause DEF to breakdown reducing shelf life.
  • Storing DEF at 86F reduces shelf life to approximately 12months.
Can DEF freeze in the vehicle?
Yes. However, Ford Motor Company vehicles have a tank and line heater to ensure the vehicle operates in extremely cold climates.
Old 12-22-2009, 01:01 PM
gearloose1 gearloose1 is offline
gearloose1 has a good reputation on FTE.gearloose1 has a good reputation on FTE.gearloose1 has a good reputation on FTE.
There will be aftermarket solutions coming out real fast... it is not rocket science to make this stuff.
Old 12-22-2009, 01:51 PM
Former Vendor
Quote:
I'm just putting out the info, thought it was strange to have a exhaust fuild. While under warranty I wouldn't use anything but the Motorcraft.
FAQ
Old 12-22-2009, 03:35 PM
senix's Avatar
senix senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
so as long as you use the motorcraft API cerified stuff, like antifreeze I would think you would be ok?
Old 12-22-2009, 07:08 PM
sandmanf250 sandmanf250 is offline
sandmanf250 is gaining momentum as a positive member of FTE.
it's cow pee
Old 12-22-2009, 07:38 PM
LOL...
Under the law, FORD cannot void your warranty for using non-Ford parts and supplies that meet FORD specs.
Magnuson?Moss Warranty Act - Wikipedia, the free encyclopedia
The key is.... MEET or EXCEED FORD specs.
Old 12-22-2009, 08:40 PM
cheezit's Avatar
cheezit cheezit is offline
cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.
man i was so gonna just post this bahhhh.
Old 12-22-2009, 08:53 PM
PowerStrokeHD PowerStrokeHD is offline
PowerStrokeHD is a splendid one to beholdPowerStrokeHD is a splendid one to beholdPowerStrokeHD is a splendid one to beholdPowerStrokeHD is a splendid one to beholdPowerStrokeHD is a splendid one to beholdPowerStrokeHD is a splendid one to beholdPowerStrokeHD is a splendid one to behold
LOL...
I have to agree... This is actually one area that the MM Warranty Act would protect you. As long as the DEF you purchase is API certified, there should be no issue.
Here is a link to what will be the DOE's DEF Locator... http://www.afdc.energy.gov/afdc/locator/def/
Some additional info on Motorcraft DEF... Ford recently signed a contract with Terra Environmental Technologies Inc. to provide the DEF that will be used as factory fill as well as what will be branded as Motorcraft for dealer and consumer use. Terra also holds exlusive supplier contracts for DEF with Daimler and Hino, and preferred supplier contracts for DEF with Volvo NA and Mack Trucks NA.
Old 12-23-2009, 12:36 AM
biz4two's Avatar
biz4two biz4two is offline
biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.
Thumbs up
GREAT info post Ed! Thanks...
I wonder what FORD is going to $$ charge $$? That is really my main concern...
biz
Old 12-23-2009, 12:15 PM
Former Vendor
biz
no price listed yet when I went and checked.
Old 12-23-2009, 05:47 PM
Quote:
Just a minor issue: I don't think API is the certification authority for DEF.
Don't know who or what it will be....
Old 12-23-2009, 05:48 PM
Quote:
It will be so widely used that you shouldn't see it as a problem...
Too many truck makers are all using the same solution not to have clones out almost right away.
Old 12-23-2009, 05:56 PM
Former Vendor
exhaust fluid?
this sounded like a muffler bearing or lifters for a V.W bug.......
but once I read it I thought I got to post this on FTE....lol
Old 12-24-2009, 12:00 AM
Ed,
It is my understanding that the prices should be in the system on Friday - 01/01/10.
For those who are wondering about part numbers. The following applies to USA. Canada may have different part numbers...
PM-27-1G = 1 Gallon Fast Fill Bottle w/ No Spill Nozzle
PM-27-J = 2.5 Gallon Jug w/ No Spill Nozzle
Old 12-24-2009, 12:10 AM
Honestly I do not believe that there is a "official" certification authority for DEF. Even API certification is voluntary. The key is that the DEF meets ISO22241 standards, which is what API will be using for its certification standards/minimums. The API certification will just give consumers proof that the DEF indeed meets the ISO standards and by doing so should eliminate any issues with Ford.
Here is a link to the API DEF site... Welcome to the API Diesel Exhaust Fluid Certification Website!
looking to buy first diesel turck luckypunk 6.0L Power Stroke Diesel 13 06-13-2015 06:59 PM
TSB 11-10-10 frt2599 6.7L Power Stroke Diesel 5 10-31-2011 07:42 PM
Am I missing anything on this Oasis? morrisjl2 General Diesel Discussion 5 04-30-2009 04:00 PM
my oasis report indebt 1999 - 2003 7.3L Power Stroke Diesel 7 11-07-2008 10:29 PM
Bye Bye Mercon/DextronIII Hello Merc V ccerniglia Oil & Lubrication 18 10-17-2008 11:51 PM
Tags
2010, 67, 67l, def, desel, diesel, exhaust, filter, fluid, ford, fulid, motorcraft, scr, truck, trucks, urea
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
