truck temp gauge won't get into the normal
Old 12-21-2009, 03:18 PM
drunkenrich's Avatar
drunkenrich
drunkenrich is offline
So my 93 f250 runs well but it won't get into the normal on the temp gauge. It moves a tiny bit but won't get into the normal. Should I worry? is this bad? I do have heat so it makes no sense to me. thanks
Old 12-21-2009, 03:27 PM
phoneman91's Avatar
phoneman91
phoneman91 is offline
Is the heat from the heater hot?? Or just warm?? If the heater is HOT-but the temperature gauge is low-I would suspect that sender on the V8 intake manifold is bad. Remove the wire to the temp gauge sender and ground it momentarily -the gauge should max to the hot side of the guage. If that occurs-the sender is bad.
If both the heater and the gauge are low in temperature-I would suspect that the thermostat isnt closing-and if so-you should replace it. Bad MPG and more wear on the engine.
Old 12-21-2009, 04:45 PM
WhiteZombie's Avatar
WhiteZombie
WhiteZombie is offline
i would replace both my guage problem was a combo of both not working properly.
ldroste
02-03-2013 10:25 AM
truckeemtnfords
03-04-2011 12:37 PM
Shade
20
01-06-2010 07:30 PM
boatnut00
04-27-2006 04:57 PM
nightowl_52
05-14-2004 12:53 AM
Quick Reply: truck temp gauge won't get into the normal
